Help for Newbie (1 Viewer)
nannyjan
125
56
Forest of Dean, Glos
Coach built
New end of March 2010
Hi, I collect my new motorhome at the end of March and I was wondering what can be recommended for keeping the MH cool in hot weather as I do not have airconditioning.
I was thinking of buying the Endless Breeze Fan along with the Blackfire Ceramic Dashboard Fan that has both hot and cool functions. Does anyone have experience of these products and can I use both of these whilst stationary or wild camping or will they use a lot from the leisure battery.
I have read the points registered regarding the importance of carbon monoxide gas alarms and was looking athe magic Safe Gas Alarm which covers other gases. Would anyone recommend this to me or possibly a better one?
As you most probably have realised I am a complete novice and obviously a lot to learn and I would like to tour Europe when I have built up experience, knowledge and confidence in motorhoming. Are there any novice groups that organise trips together or other organised trips that novices can tag along to gain the much needed experience and knowledge!!!!!!!!!
Apologies for lengthy message but so much to learn!!!!!!!!!
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
Hi No problem asking anything on here my freind.We were all novices once
If cooling is really important to you then you can always retro fit a roof mounted unit. they are not cheap and not good for older vans with flexible roofs.
Other than that you can get a stand alone air con unit but you would need mains power.
Most people put up with the hot weather and sit under the awning outside but this isnt possible in the wee small hours.
Have you got a heki roof light. opening this will let lots of hot air out.
Phill
finby
217
norfolk
coachbuilt
about 8
We open everything - door, windows and rooflight. That usually gets a draught flowing nicely, but to be honest you dont very often get weather so extremely hot and breezeless in this country that you would need any special air con units or such like. Possibly a portable fan, but weve never had reason to get one:thumb:
747
20
Tyne and Wear
Hi there,
I used to have an Elddis Autoquest 120 which is the rear lounge model. It could get very warm, even when travelling with the windows cracked open in the cab. This is because of the big rear rooflight and lots of windows.
Your model should not be affected so much but I had the dogs in the back so it was a problem. I fitted a fan of about 6" diameter which plugged into the cigar lighter. I made a bracket and fitted it low down on the back of the passenger seat to blow cool air into the back of the van. It had a noticeable effect, so you could try that.
If you do something similar, you need to be aware that the fan can run down your engine battery when the engine is switched off. When on hookup, the Elddis models do not recharge the engine battery as standard.
A lot of these fans can oscillate, which would be better if you are sat in the van in hot weather.
Hope that helps.:thumb:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
All we have is a £10 cheap 'n' nasty truckers 12V fan. We've survived. Yes you can use them off the leisure battery.
About ten of us head for Italy on May 10th, we get to Lake Garda for 10 days then do our own thing, which for some is Florence, Pisa, France. Still time for you to get organised.
dencol
79
Lancashire
Autosleeper
Only travelled in this country not abroad so my only experience is of the two hot days we've had in the last three years :ROFLMAO:
Many years ago I bought a free standing small fan that runs off mains / 12V / Size C batteries don't use it via the van 12 volt system as it does take its toll on the battery. Cannot think where I got it from but most camping rather than caravan shop have modern versions. It works fine for me and can be moved into the awning. Did have a cheap dashboard fan runs of the cig socket when travelling but could never get it to stick to these modern dashboard plastics and the one that is attached to the cig plug just got in the way.
I do remember from my school days of some 30 years ago a science class experiment whereby we placed a fan in front of a thermometer and took a reading. Then placed a small bowl of water just in front of the fan, the reading went down another 10 degrees may be a thought. I cannot tell you the theory as to why this happens, I decided to place the blades of the fan in the water and got thrown out of class before they explained it :Blush:
Colin
N
nannyjan
125
56
Coach built
Thanks for advice Brian and Italy does sound tempting. Will talk to you once I have got used to Motorhome and pluck up the courage to hit the road!!!
rainbow chasers
3,680
1,725
Mid Cornwall
Various
I think either homebase or b&q are doing stand alone units for £40 odd at the moment. Only good for when on hook-up, but the roof mounted ones only work on hook up!
Jaws
23,830
72,337
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Same as Brian here ( though cheaper still .. got it at a boot sale for 50p ! )
If you go abroad and it gets too hot the answer is simple.. Find a shady spot and siesta !!
Works for the local folk and 100% works for me !
TinaGlenn
180
Near King's Lynn
9 years
In hot weather keep your curtains or blinds closed to keep the sun out of the van, be aware if you have a Heiki roof light (kind of big skylight!) you aren't supposed to close the blind with the window closed so open it to let the heat out but close the blind to reflect the sunlight and heat out.
our van has a window in the back wall and I often have this open on the night setting as we are driving, it allows cool air coming in through the cab windows to flow out at the back.
You can buy water mister bottles with fans attached these are great for cooling you down, I also have an old fashioned fan which works very well too, although not when driving obviously :ROFLMAO::ROFLMAO: If your van has an awning fitted, a company called lillypad leisure sell heavy guage net blinds which thread into the front edge of the awning and also help to creat a shadey area to sit it.
We put an old duvet over our mattress and use cotton sheets to absorbe sweat and keep us cool at night.
It's amazing how you can acclimatise to hot weather when you can relax, sit and watch the world going by.
Relax, get out there and enjoy getting to know your new van
Tina
ourcampersbeentrashed
7,574
4,348
East London
well over 5 years
Hi and welcome
Why not meet up with some of us
There are some good meets coming up soon.
Peterborough Show which needs to be booked by 1st April
and a summer meet which needs to be booked (only £30 deposit) by 31 March 2010.
Have a look in the rallies and meets forum
