Help ! electrics/fuses ?
Discussion in 'Motorhome Chat' started by Moodybrook, Jul 7, 2013.
  1. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    784
    642
    Dumfries
    Hi, just back from first ever outing , connected to electrics hitch on site. 240 sockets fine, later tried internal lights, Nothing ! I must have had switch settings wrong at connection. Peugeot boxer 2008 2'2 Hdi . Elddis Sunstyle 140 Where do I start. Trip switches are OK.
  2. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    I think on the Eldiss you have some switches near the hab door, our previous 2006 Eldiss 160 did.
    If they are the wrong way around you may not have the 12V circuit switched on.
    The lights work off the 12V supply from the leisure battery even when you are on 240V hook up....
    Welcome.....:welcomefunster::welcomefunster:
    :BigGrin:
  3. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    Check three things
    1. make sure the ignition is off, remove key to make sure.
    2. the large black switch next to the electric step lower/raise switch.
    3. On the control panel, set batery selection switch to "AUX".
    You should see a good 12V on th gauge, over 13V with EHU connected.
    If you have to deal with the three blue 15A fuse in the top half of the panel.
    Good luck
    Gordon
