Help, Ducato
Discussion in 'Tech/Mech General' started by LOOSE WHEEL, Feb 17, 2016.
  1. LOOSE WHEEL
    LOOSE WHEEL Funster
    Mar 31, 2015
    84
    78
    WORCESTER
    Hi everyone
    I own Ducato based bessacarr E705
    I do all my own servicing,
    The rear wheel bearings are of the tapered roller type held in with a nut
    With a edge that you nock over to lock it on.
    I,v used mine to the point it needs a new one.
    It seems that Ducato have stopped supplying them on there own you can only
    Purchase them with a complete wheel bearing kit.
    As anyone had this problem and have you found any.
    I surpose garages don't worry about this and just put it on the bill but I do
    Mind paying £50 when I only need to spend £3.
    Would appreciate any help.
    Regards Andy
  2. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,644
    3,477
    Telford, Shropshire
    I don't know where you can get just the nut from but I have to ask why you have been removing it so often? It should only need removing to replace the bearing.
    D.
  3. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,262
    1,334
    Dronfield - Derbyshire
    I think you will need to spend a bit more than £3 for the wheel bearing.
    See if you can find the number on the bearing and try looking on the internet.
    I do know the front wheel bearings need a BIG press to push them out the hub.
    Suppliers like Unipart like to sell complete hubs but the price of the kits seem reasonable.
  4. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,380
    3,154
    Kendal, Cumbria
    He's asking about the nut on its own.
    • Like it Like it x 1
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,380
    3,154
    Kendal, Cumbria
    There appear to be a few advertised on eBay?
    • Informative Informative x 1
  6. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,262
    1,334
    Ooops I was confused it's not unusual
  7. LOOSE WHEEL
    LOOSE WHEEL Funster
    Mar 31, 2015
    84
    78
    WORCESTER
    Thanks for your replies
    The ones on eBay are for the front which are about three times
    The size of rears,
    The answer for you Dave is I checked and re greased them when I
    Bought it 3years ago. And I.v just had a advisarey on mot on lose
    Wheel bearing .
    So because it's starting to show it,s age (a bit like me) I thought
    I would fit a new one that's if I can find one.
    Going to Italy though swistaland don,t fancy loseing wheel On one of those passes.
    There again don,t fancy loseing a wheel full stop.
    Regards Andy
  8. LOOSE WHEEL
    LOOSE WHEEL Funster
    Mar 31, 2015
    84
    78
    WORCESTER
    I stand corrected there are some in Germany £20 :cry: with the post,
    There must be some in thr Uk somewhere.:)
    Andy
  9. dave newell lvs
    Oct 31, 2008
    2,644
    3,477
    Telford, Shropshire
    If you've got play in a wheel bearing then replace the bearing. I wouldn't chance a bearing failing for the sake of a £50 bearing.
    D.
