Help!!! Don't know what to do now.
Discussion in 'Motorhome Chat' started by The Cruisers, Mar 25, 2016.
  1. The Cruisers
    The Cruisers Funster
    Aug 19, 2015
    1,156
    3,403
    West Sussex
    Please bear in mind we are new to motor homing. Yesterday we arrived at a rally on a field in the rain we were told where to go. They said they were placing us in that particular place as it was fine. We did as we were told (unfortunately) and then we got stuck, wheels spinning etc. They got the farmer and tractor and towed us to a drier more solid area but it was on a down hill slope. We made huge ruts getting here and all around us is ruts. The tractor pulled us up onto ramps. This morning we now realise that was a HUGE mistake. How are we going to get off the ramps. We won't be able to reverse off as that will be reversing uphill on boggy ground and we can't go forward as we are up the ramps. Weather forecast is rain for the next three days so it will definitely get worse. I am thinking I want to go home or at least get off this field before its too bad.
    Don't get me wrong we are used to mud and huge ruts with the caravan but having a big car to tow we were always fine. First time on a field with the MH and I'm worrying a bit!!!
    I don't think the rally officers knew what to do either. They are a friendly bunch and helped us but helped us to what??
    You are probably going to say what idiots we are for not thinking about what we were doing but hey we've done it now - so any suggestion please would be gratefully received.
    • Like Like x 1
  2. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    465
    591
    Nr Hastings, East Sussex
    Suggest you go and chat with other motorhomers on the rally - see if you can borrow several sets of mud mats to lay a path to drive along. If you can at least get 2 or 3 sets then you can keep moving the rear ones to the front etc.
    If it's only going to get worse over the weekend then doing it today might be the solution but it has to be your judgement as to when to try to move.
    I got stuck once (on the flat) and used the breakdown service provided by Fiat to get me off so that's another option.
    Good luck!!
    • Like Like x 2
    • Funny Funny x 1
  3. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,888
    1,634
    Bungay Suffolk
    Get the farmer back to tow you off and then go home.
    Good luck mate.
    PS. These vans do get bogged in on a wet lettuce leaf, so its not just your fault.
    Most of us on here have had the same thing happen at some time or other.
    But we now tend to "walk" the intended route prior to driving the van on.
    (as I am sure you will now do in future.)
    DONE let it put you off the pleasure to be had in this fabulous lifestyle !!
    And again, Good luck.
    Mitch. (y)(y)(y)
    • Like Like x 4
    • Thanks Thanks x 1
  4. Allanm
    Allanm Funster
    Jun 30, 2013
    3,117
    4,249
    Cotes d'armor, France
    If the front wheels are on the ramps it should be easy to reverse off them ( the driving wheels will be on the ramps so won't slip) then drive down the field slowly.
    But, I would get one of the rally organisers and the tractor at the ready!
    • Like Like x 3
  5. The Cruisers
    Aug 19, 2015
    1,156
    3,403
    West Sussex
    Thanks for that both of you but the other question is how to reverse off the ramps backwards up hill. We have milenco quartos with stepped levels.
  6. dabhand
    dabhand Funster Life Member
    Feb 19, 2014
    1,494
    2,597
    Staffs
    Forget all about it till its time to go home, enjoy the rally then let the farmer tow you off, simples, it was a bit like that at Chester last year, although it did dry out a bit, no sense in worrying!
    • Like Like x 8
  7. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,755
    3,254
    Eastbourne East Sussex
    As your driving wheels are on the ramps you should be able to reverse off, then once the ramps are out of the way you should be able to move forward as it will be downhill. Don't then stop for anything till you're on firm ground.
    • Like Like x 2
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,321
    YO11 2BD
    Unless you are using garage type ramps with a very high lift just drive over the front edge slowly.
    Your ramps will only be around 3" to 4" high max.....no different to driving up or down a kerb.
  9. Hollyberry
    Hollyberry Funster
    Apr 24, 2011
    3,869
    7,624
    Paignton, Devon.
    "You are probably going to say what idiots we are for not thinking about what we were doing but hey we've done it now - so any suggestion please would be gratefully received."
    No, no ones going to say that--- cos if we haven't actually been there, we've all been close! You'll laugh about it later....
    I managed to laugh when sat nav took me down a track that ended in the middle of a field. ( why did I follow it???) French farmer told me to carry on, 200 metres there'd be a bitumen road. He didn't mention the foot deep mud and low branches across the track that ripped the TV aeriel off. The laughter had just a touch of hysteria as that night it rained inside my motorhome.
    • Like Like x 4
    • Funny Funny x 2
  10. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,872
    2,241
    Lincs
    Do not try to drive over the front of Milenco Quatros!!
    • Like Like x 11
    • Thanks Thanks x 1
  11. pappajohn
    Aug 26, 2007
    29,704
    17,321
    YO11 2BD
    Why ?
    I'm sure plenty of folks have inadvertently overshot their ramps with little effect.
    Apart from the rear kicking up I see no problem....but I only ever use regular milenco's
  12. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,872
    2,241
    Lincs
    Because Quatros are somewhat more than 4" high! Depending on ground clearance (which may by reduced by sinking into the mud), there is a fair chance of grounding on the ramps if you try to go over the front.
    Some vehicles would get away with it. Careful measurement would be needed first, but the chance of damage to the underside of the van is considerable.
    • Like Like x 4
    • Useful Useful x 1
  13. pappajohn
    Aug 26, 2007
    29,704
    17,321
    YO11 2BD
    Ok, I'll give you that one (y)
    I didnt realise they are 8 inches high.
    • Like Like x 3
  14. FIDGET
    FIDGET Funster
    May 7, 2011
    2,904
    5,999
    Isle of Wight
    I agree with @TheCaller , dont attempt to drive over the top (disaster)
    Be carefull when reversing off the quattro' or any other wedges as if reversing is up hill the wedges may shoot out the front because of front wheel drive(don't let anyone stand there). take it slowly in reverse & you should be OK.
    Also tractor more than likely wont be able to tow you back as most moho's dont have towing eye or similar at the rear.
    • Like Like x 1
    • Thanks Thanks x 1
  15. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    Oh my...reading threads like this I do miss our go anywhere 4x4 demountable camper..depths of Swedish winter in 6 foot of snow no problermo:)
    • Like Like x 1
  16. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,583
    22,481
    Narrfoook
    Depending on how steep the slope you are on is, it is well worth trying to simply roll off the ramps..
    But as already said, if it is your driving wheels that are on the ramps there is every chance you will be able to simply drive off them.
    Of course getting from off the ramps to solid ground is still a problem but easily resolved with said tractor :)
  17. mikebeaches
    mikebeaches Funster
    Feb 22, 2010
    1,032
    680
    Bristol
    As others have said, it should be relatively easy to drive/roll very slowly down the ramps, even though you'd be reversing up hill.
    But if it was me, BEFORE moving the van backwards off the ramps, I would place some anti-slip mats (or an old piece of carpet or whatever you, or other ralliers have) at the bottom, so the driving wheels of the van come to a standstill on the mats. It will then depend how soft the ground is as to whether you can just drive off forward downhill.
    But, you need to make a judgement on that before you move the van off the mats. If necessary, see if you can get help with more mats that you can borrow to make a track downhill.
    My final tip would be - assuming you have a manual gearbox (can't advise on auto) - try not to touch the accelerator pedal at all whilst you are moving off from stationary downhill - use the tickover of the engine until you are just moving, then apply the accelerator VERY gently.
    Personally, I'd be inclined to move to a better position (or right off the field if necessary) before the heavy rain sets in tomorrow.
    Oh, and please DON'T drive off the front of your Milenco quatros, as one poster suggested!!
    Hope you get sorted OK - which I'm sure you will.
    Strangely - and as an aside - we got stuck in a gateway to a temporary National Trust car park on our first outing in a MH, and at this time of year too. Beforehand, I said to the NT steward, the route didn't look suitable for us, but he insisted we'd be fine - but of course we weren't. From that time on I've always trusted my own judgement, not somebody elses! It caused chaos because it was a Sunday and our van blocked the way for all the NT visitors at a large and popular site. And even after we were towed out, the entrance was by then completely buggered up.
    • Like Like x 1
    • Thanks Thanks x 1
  18. ianthebuilder
    ianthebuilder Funster
    Oct 24, 2015
    3,384
    8,610
    Helgas house
    I wouldn't drive off your blocks either,, I did that by mistake a few weeks ago! Hell of a drop !! I was lucky they were under back twin wheels. But I wouldn't advise!! X
    • Like Like x 1
  19. wingman
    wingman Funster
    Feb 10, 2013
    985
    2,490
    Romford, Essex
    Do we know what happened in the end?
  20. ianthebuilder
    Oct 24, 2015
    3,384
    8,610
    Helgas house
    It would be nice to find out??
