Help Dometic Fridge (1 Viewer)
Clive
1,296
1,782
Canvey Island
:(I've been away for over 2 weeks now and the fridge has been working on a mixture of gas and electric without any problems. The last week purely on gas. Noticed yesterday that it didn't seem as cold so turned it up. Got up this morning and the fridge is no longer cold and everything has defrosted in the freezer.
Any ideas would be gratefully received
Clive
Clive
1,296
1,782
Canvey Island
No gas is fine, fridge is lighting ok, everything but the temperature shows its working
Feb 24, 2013
13,054
101,387
Bolsover, Derbyshire
Hymer S800
not long enough
This will probably sound bonkers, but mine sometimes doesn't work the colder I try to set it, might be interesting to turn it to a half way setting and see if it improves (y), although I don't think mine has ever actually defrosted
GJH
29,450
38,827
None, now sold
2006 to 2022
Have you still got your vent covers on Clive? That would make the fridge less efficient at this time of year. We have also found that when the weather is warm the fridge works better if turned down rather than up.
R
Robert Clark
Two suggestions
Remove external winter vent covers if fitted
Is the van level?
Needs to be within 6 degrees if level or the coolant can't circulate
Hope this helps
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I had that problem last summer in France. Spent a couple of hours on an aire, dismantling the burner and cleaning the jet, then all was fine.
(Don't poke anything through the jet - just blow it and brush away any soot.
Jim
Ringleader
Jul 19, 2007
36,329
130,307
Sutton on Sea, UK
Adria Panel Van.
Since 1988
When the weather is very warm, you'll find there is a sweet spot for your flame . Turning it high on max cooling can often result in it warming up. Turn it down a notch and experiment to find that sweet (coldest) spot on the dial. Sounds crazy but it works.
Jim
Ringleader
Jul 19, 2007
36,329
130,307
Sutton on Sea, UK
Adria Panel Van.
Since 1988
If you want to properly service your fridge its not to difficult to do
Clive
Clive
1,296
1,782
Canvey Island
No all the vent covers are off. The sweet spot on mine is 2 lights. Now I'm dressed, didn't want to frighten the locals I've taken the bottom vent off and definitely have a nice blue flame. I've had problems with the terminal block before so I've taken that off and sprayed with switch cleaner. Just a waiting game to see if the burner keeps running and the fridge gets cold again
Aug 6, 2013
11,951
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Not any more - at least not on a Thetford and probably not on Dometic now. The gas now has a thermostat.
Jaws
23,832
72,344
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
We first noticed the fridge was not great while in Croatia.
The rest of the family went off and I took it apart to see what was what
Lovely blue flame and it all looked spotless.
When we finally got home I ripped it down again and this time removed the burner out and cleaned it all up until it shone.
Also used a proper 'jet pick' and cleaned the tiny hole in the restrictor valve that feeds the burner
When I put it back together I immediately noticed the difference in the sound the burner was making..
Much noisier !
Fridge worked just fine after that.. I now strip and clean the thing at least once a year
I never really noticed the drop in performance until it was quite bad.. It is a slow process I guess and just creeps up on you..
Jan 28, 2008
10,113
18,366
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
and ive just realised he didnt mention testing the gas connection he had disturbed
Jaws
23,832
72,344
Thetford Norfolk
C class, Chieftain
why would you put the burner back and then clean the flue way so any carp falls on the freshly cleaned burner
You think folk keep fish up the flue ? No wonder so many people have problems !!!
Petest
199
185
Uk
New convert
Much noisier !
What model fridge is it?
Mines a RM7270 and not working on gas (just started another thread).
Any tips?
Jaws
23,832
72,344
Thetford Norfolk
C class, Chieftain
Makes no odds Pete.. They are basically all the same mate..
I have sorted out identical issues in various fridges from both Dometic and Thetford
Petest
199
185
Uk
New convert
@Jaws
I've got the fridge out and the burner in my hand. Looking through it should it be completely clear on the centre hole?
I can see a very fine mesh. (Burner jet 43 according to the parts list?)
Thanks in advance
Petest
199
185
Uk
New convert
Cheers guys. All working again (at least it's alight at the moment.
I've ordered another jet to keep as a spare.
Thanks again
Petest
199
185
Uk
New convert
Just an update.
I've fitted the new jet, all fired up. Now got to wait to see if it gets cold (the old jet that I wiggled a pin into worked but wanted to use the correct size so watch this space)
Feb 9, 2008
8,944
18,697
Corby, Northants
Coach Built
If it fails to cool down sufficiently, I would check your flue, it may have too much soot in there which will need removing.
Petest
199
185
Uk
New convert
Only chilling slightly at the moment. Going to leave it over night to see what happens
Petest
199
185
Uk
New convert
Is the flame size meant to visibly alter when you turn the temperature control (like a hob)?
Oct 29, 2008
5,058
5,911
West Yorkshire
PVC
since 2008
Much noisier !
Ive had exactly the same experience and you can clearly hear the difference between a partially blocked jet and a clean one. the clean one has a slight roar.
Apr 9, 2013
663
373
Ayr
Newbie
I was rather surprised by the lack of mention of sweeping in the servicing video. Having just removed a heap of soot with this "pull-through" that no amount of waggling with a screwdriver would have removed, it seems a fairly serious omission.
