HELP! Dometic Fridge Problem
Discussion in 'Tech/Mech General' started by OldWomble, May 29, 2016.
  1. OldWomble
    OldWomble Funster
    Feb 22, 2015
    70
    22
    West Sussex
    Hi all
    we are just about to go away for a few weeks and the fridge won't turn on - has anyone else had this problem? or any ideas what we can do? Due at the tunnel tomorrow pm but can't go 5 weeks without a fridge!!!
  2. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,902
    Corby, Northants
    Not had this problem before. Just make sure you are hooked up, lecce is on hold the on switch in for a while!
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,540
    9,962
    have you got a 12v supply to the fridge? nothing else works if 12v is off. check by seeing if the lamp lights when opening the fridge door
  4. OldWomble
    OldWomble Funster
    Feb 22, 2015
    70
    22
    West Sussex
    No lamp on but there is a supply (12v) to the back of the fridge. The fuse is ok so any other ideas? Cant get hold of a Dometic engineer until after we are due to leave
  5. Dorset Diver
    Dorset Diver Funster
    Dec 23, 2014
    372
    189
    Somerset
    Might help if you gave more detail. What fridge? Will it just not go at all? Have you tried it on mains, gas, and 12v?
  6. Clarky
    Clarky Funster
    Oct 30, 2010
    988
    1,498
    Suffolk or France or ........
    Is this a newish fridge?
    Our almost new fridge/freezer packed up on the hottest day of one trip last year and in the most remote aire we stayed at.
    It was a ribbon cable (like a computer cable) that runs down the back and hadn't been firmly pushed into the socket at the bottom to lock it into place, presumably in manufacture. It had wriggled free as we travelled.
    It seemed to control everything as everything refused to work until it was pushed back into the socket, with huge difficulty due to the poor access.
    Hope you get it sorted.
    Richard.
  7. Stonemags76
    Stonemags76 Funster
    Aug 14, 2011
    127
    79
    Derbyshire Dales
    Are you level? Ours won't work on our drive! Took me ages to work out why!
  8. TheBig1
    Nov 27, 2011
    7,540
    9,962
    can @Johns_Cross_Motorhomes not get you in quicker?
    • Thanks Thanks x 1
  9. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,341
    5,353
    East Sussex 01-580-881288
    Unfortunately the workshop is closed on Monday as its a Bank Holiday otherwise I am sure Glenn would olblige
    Peter
  10. Dorset Diver
    Dec 23, 2014
    372
    189
    Somerset
    Just a bit of reassurance. They do have good engineers across the water and whilst it is not ideal you could go and get it fixed in France.
  11. OldWomble
    OldWomble Funster
    Feb 22, 2015
    70
    22
    West Sussex
    Just had a Dometic engineer ring me back and taken some details. Hopefully he will have a new PCB in stock.
    S & G Caravan Services from Worthing area. Lets hope he's got the bits - brilliant service if he has!!!
  12. CWH
    CWH Funster Life Member
    Jan 29, 2014
    2,971
    12,368
    under a wand'rin' star
    With ours, it was the motherboard behind the top front panel.
    We were away when it stopped working, had lots of ideas from Funsters & tried 'em all; in the end Him Indoors got frustrated & tried to lever the strip off and - hey presto! - it started up again (phew!) Must have pressed something significant back into place.
    Got it properly fixed after we got home though.
  13. OldWomble
    OldWomble Funster
    Feb 22, 2015
    70
    22
    West Sussex
    Hi CWH
    Yup just found the same thing. Had all the panels and covers off and found we had power to the top panel but would not switch on. Had a good wriggle of all the connections and then shorted across the switch and, hey presto, on it came. So off we go and we will get it fixed as soon as we get back by S & G who has been fantastic!
    Thanks all for all your responses and ideas.
    • Like Like x 6
  14. Rob Turner
    Rob Turner Funster
    May 22, 2015
    166
    141
    Wem Shropshire
    Don't you just love the forum!
    • Like Like x 2
