HELP !!!!!! Cobra alarm (1 Viewer)
eddieold
4
Can anyone tell me how to switch off the sensor when we go to sleep in the vehicle or leave the dog in there.
Roz gets up in the night and sets the alarm off..
We can't lock the doors and leave the dog whilst we go into a shop
Driving us crazy !!!
SandJ
1,799
818
North Yorks
Too long lol
When you lock it up press button twice in quick succession
Make sure if set for night when you turn off in morning you open a door or alarm resets
At least mine does
Mar 16, 2010
3,057
30,728
Carmarthenshire
In between
Since 1988
We had the same problem the dealer told us how to do it but we forgot:Doh:
You should have a small button with flashing light by the ignition.
We have to turn on ignition then press the button for a few seconds to deactivate the internal sensors then switch off ignition and set the alarm.
(The alarm dosn't have to be set straight away it can be set a couple of hours later as long as the ignition is not switched on)
Hope this helps it works for us and this is how the dealer explained it to us.:thumb:
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi Eddie
I can't give you an answer for your question, has all we do is draw a curtain across the middle of a night the sensors are in the front cab area,
BUT somebody may have an idea with what's gone wrong with mine, the Habitation door contact as stopped working the van alarm sets also the interior sensors but the door can be opened with no alarm being activated. Peter :Sad:
Jun 21, 2008
79
14
Haxey, Doncaster, UK
Eldiss CV80
I have a cobra alarm to set the sensors to off on the inside press the button on your key twice a red light should flash on your dash when set dont forget to disarm it before opening any doors or you will wake the neighbours
John
Aug 23, 2011
204
495
Huntingdon, Cambs
Lyseo 727g
since 2011
We have the Cobra 4405 system. To disarm the sensors we have to push and hold the small button on the dashboard until a LED flashes. This has to be done within 5 seconds of turning the ignition off .
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
It's going to depend on the system, but with ours (2005 vintage) you press the big button on the plipper key once to set the alarm, then press the small button beside it once within a few seconds to disable the internal sensors. Presumably your manual (or one found online) will tell you this?
A particular problem we had once was the boot door alarm sounding when we were driving, even though the doors were firmly shut. After many roadside stops, cursing and fiddling around I found that the metal brackets that held the switches close to the inside of the doors had worked loose and shifted inwards, so the switch wasn't closing properly when the door did.
Loose wire to the contact? Contact (or part thereof) has shifted from its original position somehow?
