HELP - Battery problem
Discussion in 'Tech/Mech General' started by algill, Jan 17, 2010.
  1. algill
    algill Funster
    Dec 12, 2007
    647
    215
    Derbyshire
    Thought we would unhook the mains electric and check the power in our batteries.
    Turns out they are completely flat!! (This is because the over cooker light was left on last time we were here).
    However, as we've been here 24 hrs now we thought the batteries should have been charged again from the EHU. Just checked the fuse which was blown (that would be why batteries haven't been charging I would think) and when I put a new fuse in it blows it straightaway.
    What do I need to do?
    Thanks in anticipation. :Smile:
  2. John H
    John H Read Only Funster
    Sep 2, 2009
    254
    24
    Anglesey
    If its the charger fuse thats blown could it be that as the batterys are totaly flat the charger is being overloaded trying to charge them ? I would try to charge them with an independant charger first to get them up to a working charge. If the've been left totaly drained for a long time you may need new to purchase new batterys.
    John
  3. hilldweller
    Dec 5, 2008
    27,739
    26,821
    Macclesfield
    How big is that fuse ?
    What battery capacity are you trying to charge ?
  4. schojac
    schojac Read Only Funster
    Apr 25, 2009
    339
    234
    Cambridgeshire
    Similar thing happened to me, flattened two leisure batteries good and proper. Don't discard them yet. It is worth, as I did with mine, leaving them on charge for three to four days. Trickle charger is best but I used a charger delivering 2 amps. I was lucky, managed to recover both of them. These deep cycle batteries will take some hammer unlike a standard car battery which would have been a bin job (not literally you environmentalists)
  5. algill
    algill Funster
    Dec 12, 2007
    647
    215
    Derbyshire
    John - Thanks for the reply. It is the charger fuse that blew and I think you're right about the overload as it just kept blowing fuses. Now back home and brought the batteries back with me to charge. What would you consider a working charge? They've been left drained for 12 days.
    "How big is that fuse ?
    What battery capacity are you trying to charge ? "
    Thanks Hilldweller - fuse is 30 amp and batteries are 2 x 110.
  6. John H
    Sep 2, 2009
    254
    24
    Anglesey
    I would charge them up to 12 volts before putting them back on the van, it may be worth letting them stand after charging, measure the voltage then leave them for 24hours and measure them again to see if they are holding a charge.
    John
  7. pudseykeith
    pudseykeith Read Only Funster
    Nov 5, 2007
    382
    105
    Leeds West Riding of York
    Hi Guys. Just a silly thought - did you connect the charger the right way + to+ / - to -
    If you get it wrong, the fuse will blow. If I am being to simplistic, i oppolergize
    PK
  8. hilldweller
    Dec 5, 2008
    27,739
    26,821
    Macclesfield
    OUCH. That's a good charger that can pop a 30A fuse.
    Modern automatic chargers do attempt a recovery cycle you might get lucky.
    Another dodge is to replace the fuse with a light bulb, a 21W will limit the current to a couple of amps and not blow.
