help batteries via solar (1 Viewer)
brianrfc
5
falkirk
c class
newbie
hi there guys im having a little problem with my leisure batteries there only a year old and knackered so time for new ones my thoughts were on 2 x 110 ah batteries but when i started looking i noticed 1 x 220 ah battery this sounds strange but does 2 x 110 batteries charge quicker or same time as 1 x 220 ah battery via solar panel also whats better idea to go for 2 x 110ah or 1 x 220 ah ? i dont really know much about the way they charge i was thinking 1 x 220ah but got told that it might take longer to charge .......i would of thought 2 seperate batteries would take longer im so confused please help
canopus
6,111
10,189
rural Lincolnshire
Carado CV640 Pro
Since 2010
More importantly in your case in a C class is probably payload. If the 220Ah weighs less than 2 x 110Ah then go for the single battery. However space is often a limiting factor. You may find you can't fit the 220Ah in without bastardising fixtures and fittings.
Peter_n_Margaret
86
62
Adelaide, Australia
"C" class 4WD DIY
About 20 years
If your batteries are knackered after 2 years, that would suggest some sort of bad treatment and you would be advised to find out why and fix that problem before you fit new ones.
Cheers,
Peter
