Help Armrest
Discussion in 'Motorhome Chat' started by maacracing, Aug 1, 2013.
  1. maacracing
    maacracing Read Only Funster
    Mar 11, 2013
    52
    10
    dundee
    Hello all, we have just changed our van to a Burstner Elagance i821.
    Looking to replace the drivers armrest but having a little trouble seeing how to remove it.
    Does any one know how this is done any help would be appreciated.
    Mike
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,102
    17,777
    YO11 2BD
    does it need replacing...or has the adjuster nut been unwound too far and the link rod has become detached ?
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,752
    10,173
    with some armrests its necessary to remove the seat and unclip the upholstery on the seatback to reach the internal bolts. others you need to remove the upholstery cover via a hidden zip at the bottom and then 3 screws into the frame.
    if you feel round the joint and there is a metal plate there, you may be lucky. otherwise its a major PITA
  4. TheBig1
    Nov 27, 2011
    7,752
    10,173
    just remembered theres a third type where you have to lever the top and bottom of the armrests apart to reach fittings. As John says though check the adjuster nut is not unwound too far first
  5. maacracing
    Mar 11, 2013
    52
    10
    dundee
    Hi, I have removed the top and bottom covers and had a look the mechanism has been damaged at some point.
  6. SteveandSue
    SteveandSue Funster
    Feb 18, 2009
    367
    97
    Guisborough North Yorkshi
    Hi Mike
    You may not need to renew the arm rest - it is probably just the bolt that has sheared - If you force the fabric back you should be able to either see the hole where the bolt should be - or the sheared bolt - pretty much any small bolt should suffice as a replacment - not easy to see I know from experience
    Steve
  7. maacracing
    Mar 11, 2013
    52
    10
    dundee
    there is a round bar coming from the side of the seat at the end of the round bar there is a pin if we could remove that the armrest would come away
  8. maacracing
    Mar 11, 2013
    52
    10
    dundee
    armrest
    Hi all, many thanks for the all the replays, Finally managed to remove the armrest via a allan bolt in the chair.
    We have had a look at it and found a way to repair it, its now refitted and working perfectly.
    Mike
