Help! Anyone fitted Schaudt LR1218 Solar to Electroblok on Hymer of similar.
Discussion in 'Tech/Mech General' started by 1Oll, Jul 14, 2014.
  1. 1Oll
    1Oll Read Only Funster
    Jan 12, 2010
    175
    86
    Cheshire
    Has anyone fitted a Schaudt LR 1218 to Electroblok EBL 101 (Hymer 564 B Class 2007)
    I was advised twice yesterday at the Stafford Show by 'experts'. One suggested connecting using a standard solar MPPT controller direct to the battery. (no readouts on Schaudt panel) and the other said that the LR 1218 wouldn't handle 2x100w panels. ( he was selling MPPT controllers).
    Fairly urgent help request, as they are going to be fitted this week.
    Thanks!
    Brian.
  2. 1Oll
    Jan 12, 2010
    175
    86
    Cheshire
    NOW MOVED TO SOLAR SECTION
  3. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,852
    1,908
    Warwickshire
    The LR1218 PWM regulator can handle 18 amps charging current so 2 x 100 watt panels should not be a problem. It is possible to fit a suitable MPPT regulator with connections to the EBL. For this you need an appropriate wiring harness with a signal cable in order to display the charge state on the Hymer control panel. That may also be dependant on using a suitable regulator. There was a post about this recently where a Funster had contacted Udo Lang at Shaudt and got a definitive answer about using a suitable MPPT regulator (3-4 weeks ago maybe). However, I have a 135 watt panel connected to an EBL99 via a LR1218 and have been very happy with the results. Whatever you fit, you might want to ensure it is a twin-battery solar regulator so that it can charge the starter battery too via the link to the EBL. The LR1218 does this. It comes with comprehensive fitting instructions and a selection of wiring harnesses to suit different EBLs
    • Like Like x 1
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,112
    5,383
    Guisborough
    • Like Like x 1
  5. cliffandger
    cliffandger Funster Life Member
    Apr 15, 2013
    2,002
    9,025
    Saltford
    Hi Brian,
    Have just sent you a PM.
    • Like Like x 1
  6. Scotties
    Scotties Funster Life Member
    Sep 23, 2008
    359
    164
    Norfolk
    Hi Brian, it's the best way, easy to fit, comes with all the interconnects and gives better results. We have just spent a week without hookup and the batteries we back up to full by mid morning. The 'experts' just want to sell you what they make the most profit on.
    Richard
    • Like Like x 1
