Help ...Alarm Bleeping sound
Discussion in 'The Beginner' started by Swanny, Mar 9, 2009.
  1. Swanny
    Swanny Deleted User
    Hi, We are new to motorhome, and we have used the motorhome four times, we have a Autotrail Cheyenne on a Mercedes, 2004. The alarm is a Toad Alarm 850T, each time at midnight, the unit seems to set itself, and the alarm startes bleeping, not an audible alarm, but just a series of beeps, so doesn't waken the campsite, but wakens us. I have spoken to Taod Alarms, and they say there are no timing devices on the alarm so they think it is something to do with the Mercedes ECU.
    Has anyone got any suggestions on what to do.
  2. sinbad1
    sinbad1 Deleted User
    Check the control pannel think there is an option to set alarm
  3. derekfaeberwick
    derekfaeberwick Read Only Funster
    Dec 1, 2007
    1,131
    8
    Berwick
    Don't get any beeps from my Merc. Doesn't sound a very convincing reply to me. :Eek!:
  4. sinbad1
    perhaps i didn't make it clear ;but if you had an autotrail you would understand
    quote from the tech data of the EC200 control unit fitted to autotrail
    Sargent Electrical Services Ltd. Copyright 2002
    Issue (draft 6) Page 8 of 10 21 October 2002​
    Water Tank Fill?
    <Start 1 Min>​
    Allows operation of the External pump for a
    period of one minute (for filling the internal
    tank from the external tank)
    Use the select button () to START (or
    STOP)
    Will have no effect if the
    External pump is already
    switched on (see above)
    Will not operate if the Internal
    (Fresh) water tank is showing
    100% Full​
    Clock Set?
    12:00​
    Access to set the internal clock
    Press the select button () to select HOUR
    Use the up / down () buttons to change
    Press the select button () to select MINUTE
    Press the select button () to exit
    Please note the clock uses a
    24 hour cycle​
    Alarm Set?
    12:00
    Access to set the alarm clock
    Please note the alarm uses a
    24 hour cycle
    Alarm = Off :BigGrin:
    Regards
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    do you mean you've fixed the problem?
    if not it appears to be exactly what it says on the box.....an ALARM CLOCK...ie-- wakey wakey, get up you lazy ba**ard!
    nothing to do with the toad intruder alarm.
    if you cant turn it off just set it for a daytime alarm time when it wont bother you...:BigGrin:
  6. sinbad1
    I don't have a problem ;but Swanny does :BigGrin::BigGrin:
  7. Swanny
    Swanny Deleted User
    Hi All,
    Just like to say thankyou for all your help, we think we may have fixed the problem, trying the motorhome this weekend, so we will soon know.
    Thanks again
    Diane
  8. pappajohn
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    :Doh: sorry mate, me 'ead 'urts...getting confused....old age...senility !!!!:Rofl1:
  9. sinbad1
    know how you feel join the club:BigGrin::BigGrin:
Similar Threads
  1. miloson
    12
    382
  2. Dan16
    15
    680
  3. Jasonsmall007
    6
    403
  4. Mark Harvey
    29
    1,681
  5. Eeoodares
    12
    742
