Help AGAIN !!!!!!!!!!!
Discussion in 'Motorhome Chat' started by FrankCoffi, Oct 10, 2016.
  1. FrankCoffi
    FrankCoffi Funster
    Dec 2, 2015
    52
    38
    Andover,Hants
    Here is another brain teaser for you !
    My Lunar Premier H592 has an onboard fresh water tank which needs to have a new tank cap insert ??
    The tank has a cap that measures about five and a half inches in diameter and the cap insert is concave and holds the feed to taps and overflow pipes and the water content sensor ! The problem is that the concave insert has broken around the edge which sits on the top of the tank opening and fractured around one of the pipe inserts. This has been caused by the fitting being too high and when you sit on the seat in which the tank sits,it pushes down on the fittings,causeing them to have fractured.
    It would appear that the fittings have been replaced in the past and they are too tall. I have glued the cap and the fracture cracks and put a batten around the base of the seat, raising it up by an inch,this has stopped the seat resting on the pipes,but a replacement would be the best bet.
    Does anyone know where I can purchase such a large size cap as Lunar cannot help, (too old and wash their hands) of any previous versions of their motorhomes and the standard caps you can purchase are too small ? Any help is appreciated,Regards Frank.
  2. Cal54
    Cal54 Funster Life Member
    Apr 25, 2014
    1,400
    8,408
    Lancaster
    Frank not sure if you have tried CAK tanks, but if not could be work a try.
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,340
    7,462
    Nr Watton in Norfolk
    Try CAK Tanks, they will have it if anyone does.
  4. FrankCoffi
    FrankCoffi Funster
    Dec 2, 2015
    52
    38
    Andover,Hants
    Thanks for your swift replies,have looked at their site and not found what I'm looking for,but will try again.Regards Frank.
  5. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,639
    14,287
    Scottish Borders
    Might be worth phoning them and talking to a human as they might have one in a box somewhere.
    • Like Like x 1
  6. FrankCoffi
    FrankCoffi Funster
    Dec 2, 2015
    52
    38
    Andover,Hants
    Thanks for that Puddleduck,always the last resort,as we get so used to the internet these days.
  7. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,086
    2,927
    Kendal, Cumbria
    If all else fails it wouldn't be too difficult to make, or have made, out of nylon or similar stock. If DiY without access to a lathe it could be made from two or more discs cut from 3mm nylon or Delrin glued together.
  8. FrankCoffi
    FrankCoffi Funster
    Dec 2, 2015
    52
    38
    Andover,Hants
    Thanks Tony,it's a thought,
  9. JJ
    JJ Funster
    May 1, 2008
    14,770
    26,410
    Have you considered asking all the folk likely to sit on the seat to lose weight?
    Just another thought...
    JJ :cool:
    • Funny Funny x 2
  10. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,423
    25,445
    Planet Zog
    I would have suggested CAK tanks as well. A very neat job with the woodwork, by the way (y)
  11. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,108
    5,382
    Guisborough
    I would have a go at welding it with a soldering iron.
    Martin
  12. alfandM
    alfandM Funster
    Mar 12, 2012
    1,034
    1,057
    sweden
    The cap you show looks the same as ours and it's a fiamma tank
  13. FrankCoffi
    FrankCoffi Funster
    Dec 2, 2015
    52
    38
    Andover,Hants
    Hi JJ, will tell the wife you say she is fat ,( come up and introduce yourself to her at the rallies :LOL: ).
    Dux, thanks for info and complement,have emailed with photo to C A K, awaiting reply !
    Martin, brilliant idea,but not sure plastic around the rim will take it,thanks.
    Alfandm, have got three of Fiammas caps and they are too small,thanks anyway.
    Regards to all Frank.
  14. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,685
    3,266
    Cumbria
    Going by your woodwork skills, I would go and buy a plastic chopping board and jigsaw a circle out of that, drill the required holes and see how you get on (y)
  15. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,584
    2,577
    Tunbridge Wells
    Looks identical to the one our 2015 Hymer, so my guess is it will be a standard bought in product that is still available
  16. FrankCoffi
    FrankCoffi Funster
    Dec 2, 2015
    52
    38
    Andover,Hants
    Thanks for that Jockaneezer,the problem is that the insert is concave and not flat.If I was to use a flat piece, of plastic,it would raise the fitting,and I would be back to stage one ,but idea is sound,thanks.
    Peter,thanks also but the Hymer one is also a flat cap and not a cup,so same problem.But thanks for your input.Regards Frank
  17. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,584
    2,577
    Tunbridge Wells
    Just been out and looked at it and the cap is in fact much more recessed than the one in your photo. Probably got a 30mm recess at least from the top. The only trouble is that it only has the holes for the pump and overflow. The third hole on yours, which I suspect takes the level control rods, is not on the cap, although there is probably enough room to drill one I suspect.
  18. FrankCoffi
    FrankCoffi Funster
    Dec 2, 2015
    52
    38
    Andover,Hants
    Thanks Peter,I've been up to C A K and they have not seen cap like mine ???
    It looks like I will have to make one using a mould and fibreglass.Regards Frank.
  19. hilldweller
    Dec 5, 2008
    27,230
    26,224
    Macclesfield
    Not rocket science to make one out of fibreglass and you and even recess a bit more.
    Or slash a few extra ££ and make it out of carbon fibre. Style !!
  20. FrankCoffi
    FrankCoffi Funster
    Dec 2, 2015
    52
    38
    Andover,Hants
    Hi all, just an update re water tank onboard filler/inspection cap.
    Should anyone else have the same problem, I found a solution in Pets at Home !!!!!!!!!!!!
    I found a non slip pets water bowl and was able to cut down the bowls rim with a jigsaw to fit the opening and the cut out the three holes I required with two sizes of tank hole saws, and finally drilled a hole for the pump cable and fitted a rubber grommet..
    Spent weeks looking for the right size cap and bowl and this was my solution. FUNNY ????
    My regards to all who tried to help me, it is nice to see people helping others and long may Motorhome Fun continue.Frank.
    • Like Like x 2
Similar Threads
  1. tonyandcarol
    144
  2. tonyandcarol
    302
  3. FrankCoffi
    248
  4. David wright
    200
  5. ****
    29
    2,057
