Help,240v fault
Discussion in 'Motorhome Chat' started by Snitrats, Apr 9, 2015.
  1. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    Any ideas what could be wrong?
    Hooked up on site yesterday ,after about an hour no 240 went off
    Hookup lead tested ok
    No trips went out when power loss,
    Trip reset does not seem to work
    Socket tester shows N fault
    Van is Swift Escape 09
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    something has gone open circuit, possibly because of loose wire .
  3. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    1,011
    1,800
    Essex
    You need to work out whether the fault is with your MH or the site leccy ...
    Firstly:
    Try a different hook up lead.
    Try plugging into a different socket.
    If fault remains - the fault is in your MH
    If fault goes away - fault is with site
  4. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    Thanks,the site has been out and tested the supply And the cable so the fault is in the van
  5. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,761
    23,214
    Narrfoook
    This may help you a little:
    http://assets.swiftgroup.co.uk/uplo.../2011 MH Tech books/Escape-tech-book-2011.pdf
    looking at it, the input to the controller goes straight from the EHU socket to the main control board.
    I am sure you have already checked, but does ANYTHING come on at all ?
    The fridge, the water heater ?
    If not then my first port of call would be to remove from mains feed, flip up the cover on the inside of the EHO box and check all the wires and actually connected and none of the screws have come loose ( quite common )
    If all well, follow the orange wire up to the box and make sure it is firmly plugged in.
  6. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,542
    2,751
    Surrey
    I had something similar, and might be worth checking. I lost power whilst in the middle of a howling gale. Checked the site trips, all fine, continuity test on hookup lead all fine. Plugged it back in, nothing. Lifted the flap up on the van EHU, and noticed the socket had loose screws. I unscrewed it completely, and tightened up the wires, put it back together and power was restored.
  7. Jaws
    Sep 26, 2008
    18,761
    23,214
    Narrfoook
    LOL !! There ya go.. same info from two of us now ! (y);)
    • Like it Like it x 1
  8. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    Thanks both for that,however all looks ok that end ,it'll have to wait till we get home tomorrow .Can not belive this the first problem in 6 years, and the first time I've left my toolkit at home.:mad:
  9. icantremember
    icantremember Funster
    Sep 2, 2010
    5,403
    7,502
    Nr Watton in Norfolk
    That's Sod's Law for you!
  10. davejen
    davejen Funster
    Aug 21, 2008
    1,263
    718
    Kirkpatrick Fleming Dumfries
    Have you tried switching the circuit breakers off and on? sometimes they look like they are on after tripping .
    Cheers, Dave(y)
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,204
    3,029
    Kendal, Cumbria
    From your first test it looks like a neutral disconnection. They can be tricky to find - for example a quick test with a neon screwdriver won't show them up. As with the rest of the advice I'd go with the loose screw theory. I always tighten the plugs on new mains leads as all the ones I've come across have been loose.
  12. C200JK
    C200JK Read Only Funster
    Dec 27, 2014
    963
    3,174
    Ireland / London
    If you're sure your EHU lead is OK then do a check at the RCD in van across the input L & N... This eliminates a neutral dropout too.
    If no power there then it's between the outside socket and the RCD.
    If power is present then check across the L & N at the output side of the RCD... If power present then it's after the RCD, if none then the RCD is faulty.
    It's a process of elimination I'm afraid.
  13. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    All sorted, the block connector at the back of the consumer unit had become dislodged , pushed back and this time made sure both clips were secure ,which they probberly weren't when it left the factory.
  14. Jaws
    Sep 26, 2008
    18,761
    23,214
    Narrfoook
    I win !! What is the prize ?
    ( Twas the last thing I suggested on my post (y) )
  15. cruiser
    cruiser Funster Life Member
    Sep 12, 2012
    3,046
    2,874
    northampton
    win win
