Hi to all
I`ve recently bought a 2007 autotrail scout on the bed above the cab there is an oblong cushion that runs the length of the bed and a small square one what are these for
These cushions will be for an additional bed. If I recall the Scout has a dinette which turns into a double bed. Normally there are tilt or sliding pieces which make the bed wider, look at the sides of the dinette, do they pull out or tilt into the gangway? If they do, you will find that your dinette cushions are now not quite big enough to fill the bed area so the cushions you refer to are to fill these holes. Probably.. I cannot be 100% sure because all models are different but have a look and get back to us for other ideas if I am wrong.
