Hello and Help Please (1 Viewer)
Mags
5
3
Newcastle
Autotrail Chieftain
Newbie
Hi from Newcastle upon Tyne.
Just bought an Autotrail Chieftain and kitting out and cleaning at the moment. Looking forward to lots of fun travelling around the UK and eventually Europe.
Need advice re bedding as our 2004 4 berth seems to have a longer than standard bed. Not sure if standard double fitted bottom sheets will fit or need to be adapted. Would appreciate advice from anyone re bedding.
Also any general advice about kitting out would be appreciated too.
denisejoe
5,616
12,041
Warden isle of sheppy
Since 2004
Don't have the same van but our bed is also longer than a standard double so fitted sheet doesn't fit. I just buy flat sheets and tuck in all round.
Denise
M
Mags
5
3
Newcastle
Autotrail Chieftain
Newbie
Thanks for answering. Was wondering about that option but not sure how easy it will be to tuck in as the mattress touches the walls on 3 sides? I suppose once on the sheet is more likely to stay on?
cliffanger
4,832
34,006
Saltford
Hymer A class
Since 2013
Welcome to Fun. I think Ikea have beds that are a bit longer than the normal size, so the sheets are a bit longer too!
denisejoe
5,616
12,041
Since 2004
It's not easy getting it tucked in as you have to climb onto the bed to do it (at least I do as I'm only 5'). It stays reasonably in place as long as you don't move around too much but it doesn't take much to tuck it back in once it's in place.
Denise
StefAndDi
408
931
Near St. Austell, Cornwall
Ceased motorhoming 1/3/16
2010 to 2016
We have dealt with Jonic on several occasions. They specialise in made-to-measure bedding for motorhomes and caravans. Everything from mattresses, bed linen, duvets and protectors.
I couldn't recommend them too highly.
Welcome to the forum and enjoy your motorhome.
Stef.
Feb 24, 2013
13,054
101,386
Bolsover, Derbyshire
Hymer S800
not long enough
http://www.jonic-uk.co.uk/
When we tugged we bought bedding from these people for our round ended island bed
They seem to have a huge range for all sorts of odd sizes
edit just seen I have repeated Stefs post with same name, must type faster
StefAndDi
408
931
2010 to 2016
When we went to the NEC show before Christmas Jonic let us take their books of fabric samples of to the Hymer stand so that we could select sympathetic colours and patterns. After the show they took all of the fine measurements themselves (most important because our MH has fixed single beds which are slightly different lengths).
We now have the bedding; all we need is the new MH to put it in.
Stef.
Puddleduck
12,378
43,951
Scottish Borders
Without at present
On and off for many years.
Hello! We are a bit further north than you in The Borders.
I was going to say IKEA (try traders on ebay for the longer IKEA fitted sheets) or king size and alter the width. If you buy a king size flat sheet from one of the discount shops (TK-MAXX or Matalan) they are easy to alter to fitted sheets for the motorhome. There are lots of instructions on the web how to do it. I only did two corners as fitted (the far corners on the transverse bed) and tuck the nearer corners in.
Jenowen
130
104
Van conversion
2 years
Having had the same problem, and breaking so many nails trying to tuck sheets round, we now use a double mattress topper inside a single quilt cover spread directly on the mattress. Not sure why, but everything stays put and is v comfortable. For a king size I'd just up the size of each element.
Oct 20, 2013
5,299
13,064
South Norfolk
Yes
We have an AT Scout, and the bed, made up, is superkingsize
We have memory foam mattress topper cut in half (too big to handle otherwise) covered with single duvet covers, then 2 kingsize duvets - different togs - one on the bottom and one on top.
Simples
Sep 5, 2012
2,109
42,110
Scotland
East Neuk Fifer
since 2012
Started to use a kingsize flat and sent hubby up ladder to tuck in but the past couple of trips we 've put on kingsize mattress protector/topper and have 2 kingsize duvets one summer and one winter, depending on weather we lie on one with other on top.(y)
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
I didn't hither with a sheet as it seemed so much hassle to try to make a bed that was up against 3 walls! I slept on one duvet, with another over me. Washing a duvet cover as easy as washing a sheet.
3
32143
Hello :) we use the jersey type fitted sheets they are like t-shirt material so stretch to cover a bigger size than you would with a cotton rigid type :D
Nov 6, 2013
3,201
228,860
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Hi Mags,
I can't add any further advice but would just like to welcome you to the forum :welc:
Apr 25, 2014
1,246
5,055
Lancaster
Overhead cab
8 years
We've found that a duvet on top and underneath is easier than messing around with sheets. We've also got memory foam on top of the matress as well
TeeCee
123
36
romford, essex
Bailey Autograph 79-4
Since 2011
Wifey kept breaking her nails whilst tucking in close to the walls......so we now use any flat object..ie a 12" plastic or wooden ruler to tuck the sides in/down or even a plastic kitchen spatula...works a treat!
