Hello All
Discussion in 'Introduce Yourself' started by Harveys heros, Jun 30, 2015.
  1. Harveys heros
    Harveys heros Read Only Funster
    Jun 30, 2015
    Swansea
    We have a problem with the step on the motorhome it will not retract when out.
    It goes part the way up but not completely. All seems ok and I have checked the fuses and they are ok.
    everything under the step is connected and I am stuck on a solution. Has anyone in the forum come across the same problem and is so how did you solve the problem ?
    Thanking you in anticipation
  2. scousebird
    scousebird Funster
    Apr 18, 2012
    14,266
    22,774
    South East Kent
    Hello :welc:
    Can't help with your query, you may be better posting your question in the Motorhome Chat section, probably get more views & hopefully an answer.
  3. f6c
    f6c Funster
    Nov 7, 2010
    3,074
    831
    gloucestershire
    Welcome aboard;) The step could be be a dirty contact get under neath you will see a grey plastic housing unbolt and clean hopefully this should work?
  4. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,027
    1,168
    Dronfield - Derbyshire
    As above
    AND
    Lubricate ALL the pivots with spray grease
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    Hi and welcome from North Devon
  6. Dawn B
    Dawn B Funster
    Oct 20, 2013
    5,214
    14,656
    South Norfolk
    Hi & :welc:
  7. Momo
    Momo Funster
    Sep 19, 2008
    2,458
    2,984
    Valencia City, Spain
    Hi Harvey and welcome to the Fun!:welc::party:
  8. greyman1
    greyman1 Read Only Funster
    Aug 7, 2011
    363
    273
    manchester
    most common reasons for problems are dirty/corroded electrical contacts , the step motor is usually a converted type of wiper motor but because it only needs to operate in a very limited range the spindle /cog can seize up . removal ,lubrication and new grease will usually sort it. regards garry
  9. movan
    movan Funster Life Member
    Dec 2, 2009
    13,273
    23,872
    Moving around
    Welcome @Harveys heros . Did any of the above suggestions of help work?
Similar Threads
  1. martinken
    17
    136
  2. simmo
    20
    169
  3. Jarod
    16
    148
  4. Bettyswallocks
    13
    218
  5. Vickytoms
    15
    312
