HEKI 2 rooflight
Discussion in 'Tech/Mech General' started by tomm, Sep 10, 2013.
  1. tomm
    tomm Read Only Funster
    Mar 2, 2011
    262
    272
    uk
    Does anyone have this particular rooflight fitted to their MH ? It seems THE HEKI 2 model rooflights were ( still are ? ) fitted as standard by a lot of MH manufacturers .
    Am looking for user opinions on the unit , good bad or otherwise , before possibly retrofitting one
    Dometic ( makers of the rooflight ) are clear on their product blurb http://www.leisurespares.co.uk/files/installation_instructions_heki_2.pdf that the units are " Designed and recommended for trailed vehicles in which people do not travel. Technically also suited to a vehicle in which people do travel . HEKI 2 suitable for max. 100 km/h (with Seitz spoiler up to 130 kmh)" (80MPH ) ..... That last bit presumably being the reason MH builders fit the units to new build MHs.
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    We had a Heki 2 on our Autoquest and found it OK. I think it's important to make sure it's shut properly before driving off though.
    The Burstner has a Heki 3 which has a winding mechanism to raise/lower it and seems more solid than the lifting bar arrangement of the Heki 2.
    That's just an impression though, no engineering knowledge.
    • Like it Like it x 1
  3. tomm
    Mar 2, 2011
    262
    272
    uk
    Thanks Graham . I have also looked at the Heki midi unit with wind up crank handle . That model is a fair bit smaller than the 2 unit though and we are looking for maximum light input . I"m not usually a buy cheapest option just because its cheapest , but the price differential between the heki 2 and heki 3 is very substantial , £ hundreds , so am looking around at benefits / downsides etc before shelling out on whatever option .
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,922
    1,944
    Warwickshire
  5. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,914
    39,984
    I have five various,,, Flip the lever and lift (Round One) in the shower cubicle... and one turn a little handle in the WC area.... and two lever ones in the bedrooms..
    Also got a crank the handle type in the main lounge... Not very impressed with this one,,, it seems a struggle to wind up, and feels as if the handle will break... so we lift the roof light as we are winding to take the weight off.... ok for closing... :Smile:
  6. tomm
    Mar 2, 2011
    262
    272
    uk
    Yes , I agree with you on that . The confusion for me is that there seems to be differing info coming from Dometic , dependant on where it is grabbed from . For example the link and following info I showed above is the Dometic pdf installation instructions for heki 2 . Clearly stating ok for vehicles people travel in , or , not travel in . To further confuse things , major MH builders were / are fitting the model to their MHs . So they are veering on the side of them being suitable for MH fitting . Possibly based on a £ per unit cost , rather than a truly fit for purpose decision ?
  7. tomm
    Mar 2, 2011
    262
    272
    uk
    Thanks Mo. On reading about these things , there are some with the opinion that they can feel a bit flimsy , requiring care when adjusting.The heki 3 models are maybe a bit sturdier ,dunno really . Will visit a couple of MH dealers for a physical check of the different units before deciding on which to go for.
  8. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,922
    1,944
    Warwickshire
    I'm not sure what make my roof lights are as they are branded Hymer, but they are raised and lowered with a crank. I recently got up on top and cleaned the crank system with an old toothbrush then coated it in silicon grease - plumbers waste pipe seal grease. Now the action is smooth and easy to operate. (The van is 10 years old so they were probably due for a clean.) I also stripped, cleaned and lubricated the hab door and garage hinges with the same grease
    Most important - don't use WD40 as it will make things worse in the long run.
    Sorry to hijack the original thread.
