Height for trailer board? (1 Viewer)
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
I need to know the minimum height for putting a trailer board on my motorcycle rack on rear of camper.
GeriatricWanderer
1,194
4,199
Ouagadougou, Burkina Faso, just cos I can!
Pop-Top Campervan
45years
Just be sure you have the right reflectors on it - seen too many boards on motorhomes with trailer reflectors.
Not a hanging offence but it wouldn't surprise me if an insurance company latched onto it in the event of a prang.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Are there any "wrong" reflectors?. In theory, If its attached to the MH (Rack) then the reflectors incorporated in the lights would be sufficient, as is the case with Vehicle rear lighting?.
GeriatricWanderer
1,194
4,199
Pop-Top Campervan
45years
Trailer boards as fitted to towed things like trailers and caravans must be fitted with 2 X triangle reflectors so when you come up behind such a vehicle you know there's more of it in front.
These triangle reflectors must not be fitted to boards on the back end of vehicles that are not towing.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
All trailers should have, by law, 2x red reflective triangles positioned at the rear of the trailer at a minimum of 250mm from the floor, but not exceeding 400mm
GeriatricWanderer
1,194
4,199
Pop-Top Campervan
45years
The OP isn't towing a trailer so should not be showing triangle reflectors.
I think he simply means a "lighting board".
PeteH
6,853
9,030
Rapido, 999M.
So Therefore my Quote "In theory, If its attached to the MH (Rack) then the reflectors incorporated in the lights would be sufficient, as is the case with Vehicle rear lighting?." Would Stand?. (Basically, NO separate reflectors?). Or is there a Different interpretation?.
EG. for example when "A" framing (Warning!!:D2) the "toad" I have Magnetic Triangular Reflectors which are removed when not being towed?.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
I dont know what he means so just answered his question reference "Trailer Board"
GeriatricWanderer
1,194
4,199
Pop-Top Campervan
45years
Yes
GeriatricWanderer
1,194
4,199
Pop-Top Campervan
45years
I have a 6 mtr van with a rack on towbar with small m/bike on. The lighting board has 2 triangles on and usual indicators etc.Thanks for answers-should be OK ?
No!
Sorry but we seem to be making hard work of this.
The triangles are only required on trailers, not on things hanging off the back of a vehicle like you are describing yours.
They are simply used to indicate to following drivers that they are seeing the rear of something being towed.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
What if the vehicle rear lights are obscured
what does he do for reflectors then?
Your point is really mute, as im not aware of any lighting boards sold without the triangles,
The lamps used on these board ie Trailer Lights, dont have any inbuilt reflectors
GeriatricWanderer
1,194
4,199
Pop-Top Campervan
45years
I can't comment on what types of lighting boards you are aware of but I can only state what I belive to be the correct fittings for each situation.
There are 2 different lighting boards.
One for motorhomes/cars etc not towing. These have round or rectangular reflectors - or sometimes no reflectors.
The other, for caravans/trailers have the triangular reflectors.
Triangular reflectors are ONLY for things being towed.
Both of these boards have been available in my local caravan/camping store for years and are clearly signed for the two different uses.
The OP was clearly asking for advice on a lighting board (he referred to it as a trailer board) to go on a motorcycle rack on the back of his motorhome - not on a trailer.
His most recent posting, in which he says he has a towbar mounted rack and a lighting board with triangle reflectors, seems to justify my first posting which highlighted the need to make sure he was fitting the right board - he isn't.
Sometimes one tries to offer help but it just picks up flack. Getting a little like Facts.
My last post on this thread.
Doctor Dave
463
1,110
Wiltshire
None
7 years followed by a break of 11 years and then 4+ years but given up now
Aug 18, 2014
23,772
133,556
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
You cannot have the lights covered,It either has to be completely above the lights, you can then use a V20 board ,although the UK doesn't insist on them or you have to have a lighting board complete with number plate etc.
Chris51
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
I will just take off the triangle reflectors then.Thanks again all for advice.
PeteH
6,853
9,030
Rapido, 999M.
Actually, Quite interesting thread, I was not aware that the use of a "Trailer" Board, would Under the condition specified, be unacceptable. So there you have it, To-days lesson!. Cheers GW!:D(y). In fact I am (have been) guilty of same "offence" when using the Old Trailer lighting board on a Rear Mounted bike rack for the Boys bikes which when mounted actually obscured the Rear lights on the old Shogun! many Moons back!.
