Heating help (1 Viewer)
Mazafer
26
7
Rotherham
motorhome Euro 140
I get it 27.07.16
how do I put my heating on in my fiat Ducati 1997
Jun 9, 2016
228
306
L'Isle Jourdain, 86150 France
C Class I think
Just bought an Eriba FT 580
Is it this one? :D:D:D:D:D
R
Robert Clark
Can you attach a pic of the heater control panel?
If not, can you say which model heater you have?
D
Deleted member 29692
Or even which model van would be a help
Fiat Ducato is the base vehicle that the conversion is carried out on, not the make or model of the motorhome itself
19,725
51,980
uttoxeter
ambulance conversion
50 years
Didn't like to make a joke of it but seeing as some now have, have you tried the switch?
CWH
5,144
247,378
UK
WildAx PVC
From November 2013
From previous posts by @Mazafer , it's a Mobilvetta Euroyacht 140.
D
Warm air heating then, either Truma or diesel.
Robert's right. Pictures needed I think.
3,869
5,262
The City of Henlow
Adria Supreme
Since 1980
There should be, if it is a Truma, either one or two dials to control the heating.
You are not alone in trying to figure out how they (or it) works.
If you have just the single dial, the inner part controls the habitation temperature when heating is switched on. The outer dial switches on the heating (gas) with one or two clicks moving the pointer upwards for hot water or very hot water and with one or two clicks downwards with the pointer for a warm or hot van. The other dial, if you have one is for electric heating, usually on hook-up. Please note that the system is quite sophisticated and may take several minutes to work and to switch off, this it is designed to do. When fully operational it should give off a good volume of warm air but not for several minutes after being switched on.
The heating duct pipes have been known to detach themselves from the heater, so if the heater is getting hot and the van is not, you could check this out.
Good luck.
