Heat Beads (2 Viewers)
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
OK, they may sound like a sex aid for cold winter evenings but the ones I bought are Australian BBQ briquettes. I bought them for our Cobb BBQ as a cheaper alternative to Cobb's own special fuel.
However, you would think a basic requirement of a BBQ charcoal is you can actually light them with something less than an oxy - acetylene torch.
They burn well when lit but what a performance getting them started.
Has anyone else any experience of these things? For info here is a link:
http://www.garden4less.co.uk/heat-beads-BBQ-briquettes-4kg.asp
simply
202
197
Devon
Renault Trafic
Newcomer
I use the same and have had absolutely no problem, I have even extinguished some with water and re-lit them the next day. I use cheap firelighters and put one white square into the base of the Cobb and drop a lit match in. I then put into place the wire basket containing 8 or 9 briquettes. The flames and smoke die down after only a few minutes and I then find I can cook for three hours or more without anymore ado.
Reactions: DBK
DBK
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
Thanks for that. We used them this evening but with only 6 briquettes. The fire lighter burnt itself out and they still didn't light. So I put the little cage over the gas hob and gave them a good roasting for several minutes, even then it looked later as if only one really lit but it got the others going a little later.
I think the problem is you need plenty of briquettes, they don't work in small numbers.
It could also be we have a duff bag. I'll try the link I posted earlier for the next lot as I think they are worth persevering with. Once they get going they are excellent.
Dec 12, 2010
5,368
21,191
Cumbria
since 2011
I use them in both my Webbers. I generally start them off in a chimney but have lit 8 to 10 briquettes with a couple of their firelighters when I use the Go Anywhere . They’re great for long slow cooks but I generally use normal lumpwood if I’m just grilling a couple of steaks. Once you have a lot of them alight, it can be hard to get the temperature to go down which might be an issue in a Cobb ? Check out Youtube for the “Minnion Method” or “Snake Method”
C
Chockswahay
I've used them on a Cobb and on normal BBQ. I must say that I was none too impressed either way quite frankly (I should add that I was not impressed with the Cobb so got rid of it straight away)
However............ I have used this recently and its fantastic!
Broken Link Removed
Just pile in the charcoal, light a couple of starters underneath, wait about 15 minutes....... bingo :D
I have also found it is the best way to start and add extra charcoal at any time after the BBQ is going :)
Reactions: DBK
C
Chockswahay
Not wishing to hijack this thread completely, I just realised what you said...........
I have the Go Anywhere........ it really is the best BBQ I have ever owned. We use it with the van but I am so impressed with Weber that I have bought the top o the range balls out Weber for my son as a wedding present :D:D
Reactions: DBK
Minxy
32,488
66,011
E Yorks
Carthago Compactline
... the mind boggles as to what you get up to if you think that Heat Beads has a sexual connotation!!!! o_O
Oct 29, 2012
887
1,043
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
Bartyfixedit
328
565
Maidstone Kent
Self Build Ducato L4H3
Since 1987
The ones you linked to are the exact ones that I get from Cobb themselves. I have used them for years and never had a problem.
I have an old biscuit tin that I stick the coals in as soon as I have finished cooking. Once the lid is on the coals go out pretty quick and are then ready to use next time. I put 6 or so new beads and then the snuffed ones on top.
If you are using the little white firelighters you need six or seven and then light them in the pit and sit the cage on top. I use the dome extension as a wind break. The coals are ready to cook in 20 to 30 minutes. Never let me down.
I am wondering if yours have been stored damp, or are a duff batch.
Reactions: DBK
Dec 12, 2010
5,368
21,191
Cumbria
since 2011
When I look back at all the barbecues I've bought over the years, I wish I'd bought a Webber first. I had the 57cm One Touch at home but my son's "borrowed" it for his new house, looks like I'll be shopping for a new one now !
Reactions: DBK
Sep 10, 2013
1,186
18,688
Chelmsford Essex
Getting better
Broken Link Removed
Broken Link Removed
I have used one for the last few seasons,agreed a 1st class way of starting the BBQ. I fill with briquettes,place it over a few wood off cuts, douse with white spirit, wait a couple of mins then light. Go and open a cool beer and in 20 mins all ready to go. Has the added advantage of measuring the correct volume of charcoal for a Weber unit.
DBK
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
Giving them another go tonight, two chicken legs. We prefer chicken thighs but only a few supermarkets seem to sell then in Spain.
Thanks for the tips, starting to get the hang of them now.
DBK
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
If you dare, Google "beads Ann Summers" but don't say I didn't warn you!
C
Chockswahay
Ohhh no, just did, wish I didn't:eek: I've lived a sheltered life:confused:
Reactions: DBK
Clive
1,296
1,782
Canvey Island
I just use good old fashioned firelighters, never had a problem getting the head beads to go, couple of big chunks in the bottom, fully alight in 20 minutes normally.
C
Chockswahay
Err, is this another Anne Summers reference?:rolleyes:
Reactions: DBK
DBK
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
Many thanks for restoring sanity to this thread or perhaps that should read decency! Jim was probably on the verge of moving us to the Belly Locker.
Jun 30, 2010
7,921
27,188
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Heat beads?
Heard of Worry Beads,
Prayer Beads'
In the 60s we had Love Beads, generally with a little cow bell on the end, ting a ling a ling, and you waited!
Ting a ling a ling, in the distance !
Ting a ling a ling closer!
Ting a ling a ling you eyeballed!
Ting a ling a ling ling ling a ling! Hey man! you've pulled!!
TING CLUNK! S**t! Oh well!
Ting a ling a ling and you waited!
Ting a ling a lingin the distance!!!!:love::love::love::love:
Reactions: DBK
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
Broken Link Removed
About 30 years ago I used to use a Nescafe catering coffee can (they made them out of real tin then!) took top and bottom off and made some holes in the bottom with a wire handle,used a lot on campsites and borrowed by fellow campers-I should have filed a patent!
Prevented beads of sweat.
Reactions: DBK
lugnutt
1,190
466
wednesbury.westmidlands
autotrail apache
10 years
ive used them for years only problem i had was putting to many fire lighters and the flames melted the rubber feet witch the inner sits on
Reactions: DBK
C
Chockswahay
You're right DBK. Actually I have often thought how quickly some threads go 'off topic' and realise that I am one of the guilty party who brings this about. :(
Reactions: DBK
Oct 29, 2012
887
1,043
essex
Rapido 9090df
Belly locker beckons:LOL:
