Headlight problem (1 Viewer)
Jim
Ringleader
Jul 19, 2007
36,404
130,782
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I have no headlights, (99 Fiat).main beam is ok. Fuses in the main glovebox fusebank check out OK. As both lights failed at the same time I'm assuming there is another fuse somewhere. Any ideas, Thanks
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Hi Jim,
If you dont get any positive answers, give my auto electrician a ring during the day and pick his brains.
Peter
Feb 27, 2011
14,732
75,880
UK
Self Build
Jim, I would check for earthing first if I were you.
I am not sure about your model fiat but on mine there are two separate fuses one for the left left and one for the right.
For both to fail I would tend to look at something in common with both.
The things that both headlights have in common would be either earthing, the relay or the switch switch.
If you get your better half to switch the lights on and off and you stick your head under the dash and under the bonnet see if you can hear the relay clicking. If not it would probably be worth checking the switch first.
If that doesn't help I would get to the switch and ensure it is getting power, then find the relays and check that power is at the input and output of the switch side.
JockandRita
11,462
150,101
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
I would concur with Karl, Jim.
The relays are underneath the glove compartment, and the lower half of the dashboard needs to be removed to gain access. You should be able to hear the click of the relay, as you operate the headlamp switch. Is it side lights, dipped beam, main beam, or all lights that aren't working?
Good luck with it, :thumb:
Jock.
Oct 27, 2007
1,816
2,361
Near Dartford
Hymer
Jim this happened to us. All the fuses checked out OK.
We also had main beam but no headlights. The problem was a loose connection with the push in plug on the wiring(connector plug)
There is a push in plug behind the cowl on the indicator lever. Kevin took the cowl off and pushed the plug back together.
Hope this makes sense.
Sonja
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
Jim,
At its last MOT (August) our dipped headlights didn't work on our 2006 Fiat (Ducato 2.8 JTD).
It transpired that there is a doo-hickey under the dashboard, behind the radio somewhere called an Ornament Switch Panel, which is some sort of computer control for the dipped headlights. The upshot was that this had failed and needed replacing. New unit - £150.68 + vat, plus hour and a half labour . :whatthe:
Trust Fiat to design such essential equipment as headlights so that a component failure requires a major repair job instead of a simple DIY fuse / lamp change. :Doh:
John
Merry Christmas to you, Sian and family. ::bigsmile:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
They suffer with loose connections and earth problems, Jim.
Firstly, check your have power on both high and low range at the headlight. This will take the relay out of the equation as to supply power to the headlight, it is working.
If there is no power, then you need to look at the relay and work your way back from there.
Use a jumper wire as an earth from the earth wire to a sound earthing point and see if that brightens things up. If so, it will be an earth
Mail me if you want a Wiring diagram.
Cully71
Peugeot boxer
Jim,
John
Sorry it's been a few years ago,but having the same problem, do you know exactly where/What the Ornament Switch Panel is? Thanks
Chris
21,051
278,607
None
10 years
This is one of those threads when annoyingly the OP doesn’t bother to come back on to tell us how they got on.
@Jim ?:whistle:
champers
4,224
8,453
Skegness, UK
Frankia i650 FD
Since March 09
Think you need to look at the date the op posted lolol ....
A new thread may get more help
Kath x :dance2::dance2:
43,323
49,428
Actually, cully71 is doing what should be considered the norm.... Searching the forums for a similar problem then asking the question there.
Not many do though as it's far less time consuming to simply start a new thread asking a question which may or may not have previously been answered.
What you have to remember though, is Jim doesn't know how to use his forum as he didn't come back with a conclusion to his problem so nobody is any the wiser. ;)
Feb 22, 2011
9,785
20,150
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Ornament Switch Panel brings up no results when googled.
Headlights don`t sound like ornaments, indicators maybe, if we were talking BMW drivers
Lot lover
1,291
1,617
Lot, France
Le Voyageur Integral
New boy
30 years ago ago Ihad a similar problem on a Bedford TK horse box. The culprit? A piece of chaff in the switch on the steering column.
Feb 22, 2011
9,785
20,150
Hymer B544 A Class
Since 2015
Ornament Switch Panel - does such a thing exist though I wonder ?
Jim
Jim
Ringleader
Jul 19, 2007
36,404
130,782
Sutton on Sea, UK
Adria Panel Van.
Since 1988
@Jim ?:whistle:
I'll be honest and say I can't remember the issue at all, let alone how it was resolved. :oops2: I've a vague recollection that @Sheriff fixed it for me, he did most of the work on my van at that time.
Badknee
7,407
412,580
notloB
Vantage Neo
Living the dream.
If it’s the ducato column switch it needs stripping down. I did a how to somewhere (n)
