Have you used Wedgies ??
Discussion in 'Motorhome Chat' started by Larrynwin, Mar 26, 2016.
  1. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,898
    13,920
    Norfolk
    Found these Alko wedgies in the tool kit supplied with Hymer . I guess necessary when parked on steep incline with auto box as no fallback if brakes fail.
    Surprising on a modern vehicle :Eeek:
    • Like it Like it x 1
  2. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,946
    12,203
    Plympton, Devon
    Probably for when you jack the vehicle up to change a wheel. Can be very useful if you have to jack up the axle which has the handbrake as the vehicle can roll away if you are not careful and fall off the jack.
    But similar things are also used with levelling ramps so you don't have to leave the handbrake on.
  3. Allanm
    Allanm Funster
    Jun 30, 2013
    3,185
    4,342
    Cotes d'armor, France
    I had these supplied with an auto Land Rover I bought years ago, the handbook said they were to chock the wheels as you were jacking it up.
    They maybe supplied with yours for the same reason because it is an auto.
    No reason you can't use them for the reason you specified, but the Park position on your auto box should lock the gearbox up anyway so it shouldn't move if the handbrake fails.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,099
    17,769
    YO11 2BD
    Generally, those chocks fit ON wheel ramps to form a cradle.
    I dont think they would provide sufficient grip on tarmac.
    • Like it Like it x 2
  5. pappajohn
    Aug 26, 2007
    30,099
    17,769
    YO11 2BD
    Only if its a true torque converter auto.
    Far too many pretend autos with robotised manual boxs.
    But then, just leave it in a low/reverse gear.
  6. Tootles
    Tootles Funster
    Sep 14, 2013
    9,251
    33,132
    Lancaster
    I use mine as a wedge for the ramps, just in case the truck wants to move off them a bit. And I know this works, because sometimes their jammed under the tyre.
    • Informative Informative x 1
  7. pappajohn
    Aug 26, 2007
    30,099
    17,769
    YO11 2BD
    I assume they have a similar ridge pattern on the underside to the ramp ridges allowing them to lock in place ?
    • Thanks Thanks x 1
  8. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,898
    13,920
    Norfolk
    They also have a steel insert on the bottom edge to aid digging in to a firm surface which you can see on the bottom of the top wedgie in the photo.
    • Useful Useful x 1
  9. Tootles
    Tootles Funster
    Sep 14, 2013
    9,251
    33,132
    Lancaster
    I don't use them that high John, I put the truck onto the ramp, then shove the wedge under the tyre, rear end of the wedge still on the ground. Any movement of the wheel 'locks' the wedge quite firmly.
  10. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,920
    1,944
    Warwickshire
    I cannot find the reference now, but I'm pretty sure I have read that some EU countries (probably Germany) require vehicles over 3.5 tonnes to carry wheel chocks for use on inclines.
    • Thanks Thanks x 1
  11. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,898
    13,920
    Norfolk
    Just checked my Hymer manual ,
    • Informative Informative x 2
  12. awg
    awg Funster
    Aug 9, 2013
    212
    240
    Essex
    I use them when parked up for a few weeks so I can leave the handbrake off. Stops the brakes sticking on. Leave it in gear and a wheel chocked front and back. It is parked on level ground.
    • Funny Funny x 1
  13. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,898
    13,920
    Norfolk
    Note to ageing receding brain, " must read Hymer manual " :)
    • Funny Funny x 2
  14. mickyc
    mickyc Read Only Funster
    Nov 30, 2009
    566
    2,015
    Spain/Portugal
  15. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,710
    14,442
    Scottish Borders
    We do the same and if parked up for a while when we want to leave the handbrake off.
  16. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,920
    1,944
    Warwickshire
    That's where I read it - just checked my manual too. But as our GVW is 3,800 kg, we didn't get chocks with ours.
  17. OldWomble
    OldWomble Funster
    Feb 22, 2015
    70
    22
    West Sussex
    Legal requirement in Germany and for all trailers too!
  18. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,898
    13,920
    Norfolk
    Mine is 3500kgs gvw which was ordered by Becks , the original plate shows 3800kgs.
  19. PeteH
    PeteH Funster
    Nov 22, 2007
    2,213
    2,760
    East Yorkshire
    As with (apparently) the vast majority of Al-Co equipped Ducato chassis. Mine sits downhill at all times and must be parked on blocks, even on the (Level) driveway!. I use wedges too so that I can park up with the handbrake off!, saves the big "Crunch" that is the seized on brake lining coming off when it is first moved after a longish lay up!!. I`v always used blocks and or wedges to immobilise vehicles and caravans, rather than the brakes, if they are going to be parked more than a few days (even bricks in the past!).
    BTW, I`ve always spelt it Wedges?. a wedgie was something eye-wateringly painful as I recollect!!
    Pete
  20. scotjimland
    Jul 25, 2007
    28,938
    25,625
    can be.. or....
    [​IMG]
    • Funny Funny x 2
