Have I bought the right LED lights (1 Viewer)
themountaintiger
355
63
Lancashire
Swift Kon-Tiki 649C Class
Since 24th March 2010
Trying to save power when no hook up and have bought some LED lights. The lights that swivel 2, in dining area and 2 in bedroom (MR16's), ive got sussed and yippee control panel is showing that instead of 0.8 amps each they are now at 0.1 each amp each.
My problem (if it is) is to do with the downlights which have a G4 in them. I found a G4 MR11 25 SMD
on ebay to try and it does fit, but im unsure if the height of it, if touching the reflector semi dome would cause any potential problems. I appreciate that the dome must have heat reflecting properties as it is for Halogen bulbs, but is there any issue with LED's actually touching the dome area?? I bought just the one to try so dont mind binning it for a better solution before buying a set of 9 that I need.
Hope this makes sense. Ive included a piccy, any help/advice appreciated...:Smile:
GJH
29,450
38,827
None, now sold
2006 to 2022
There are different types of G4 LED - see illustrations Link Removed - for different types of fitting.
I'm sure Aten would advise which is right for your fitting.
Graham
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
they have almost every type of led
Graham
I agree with Grahm have a word with Aten they have most (not all) types of replacement led bulbs.
They do not have the one for the American (Winnibago) wardrobe light.. this is a tube with metal prongs each end.. it has to be the original type replacement:Angry: know have tried to replace it .. have done all the others on my RV now and that is one lot of lights.
But it does make a differance when you have done them to the battery drain.
Bob:thumb:
themountaintiger
themountaintiger
355
63
Lancashire
Graham
Thanks graham, I had been to the Aten web site and was undecided whether a flat one would have been better. There is one that is 23mm in diameter I was considering Link Removed , but bought the one I have as due to it being similar shape..
scotjimland
2,252
9,769
A Woosh bang
snip
Bob:thumb:
You don't spend a lot of time in a wardrobe, so it's hardly going to be significant ... unless you haven't come out of the closet yet Bob ..:roflmto:
slobadoberbob
6,151
1,960
25 years & counting
still trying to get in it not out
Even I cannot hop up into this one.. still trying to get in it.. It is one of those you never are really sure it has gone out when you shut the door.. but no we could not get an LED to switch in it's place.. that is the point Jim I was making.. not my sexual preferances.. .. still a blond, about 5'10" blue eyes ....and 25 years old would do nicely.. but Sue says I would not know what to do with it???:Doh: I would die happy I know that... :Blush:
Anyway back to the wardobe... if I could only get in it and be sure it goes off:Eeek:
Bob
scotjimland
2,252
9,769
A Woosh bang
Bob
ah yes.. the old fridge light problem.. how do we KNOW it's gone out .. ?
test the door switch .. :thumb: or drill a hole in the door to look inside :Doh:
Terry
11,926
9,042
Lincolnshire
Can't remember ;)
Take the bulb out :thumb: to be certain :ROFLMAO::ROFLMAO::ROFLMAO:
terry
43,301
49,286
the flat one would be better in my opinion.
replace all mine on the kontiki with that type.
www.ledbulbs4u.co.uk do a good selection.
43,301
49,286
is this any good Bob?
LED bulbs right hand side, second row.
you remove ALL the gear tray from the existing lamp and replace it with this, simply connect to the existing switch.
saw them at lincoln and they look fine.
considering them myself but as i have 10 x twin tube fittings it works out rather expensive at over £220 :Eeek:
themountaintiger
themountaintiger
355
63
Lancashire
Thanks pappa john thats the first web site ive seen which shows if you have one of these ie. the G4 halogen buy this circular one. Ive added the link for future motorhome Funsters who might have the same issue.. Link Removed
:thumb:
43,301
49,286
:thumb:
the 9 led ones are much better than the 6 led version.
i think the 6 led are 20w equivelent and the 9 are 25w.
i used 25w in the main lights and 20w under the cabinets.
themountaintiger
themountaintiger
355
63
Lancashire
hmm trying to work out if the 9 led ones will fit as they are 3cm diameter, whilst the 6 led ones are 2.3. now wheres mi measuring stick??
C
caravanledlighting
LED Lighting
Hi,
Maybe we can help please visit us at :spam: or send me your requirements to :spam: and I will sort out your needs.
Chris
themountaintiger
themountaintiger
355
63
Lancashire
the ones in my link are the same diameter for both 6 led and 9 led
Hmm the sizes are slightly different at 3cm for the 9led and 2.7cm for the 6 led on that site although ive seen on another site there is a 2mm tolerance mentioned. Another web site shows the 6 led version as 2.3cm, looks same but cant tell if exactly the same. Ive not measured yet but would seem that if 3cm will fit then ill have the choice.
thanks for helping
