Have I bought the right LED lights
Discussion in 'The Beginner' started by themountaintiger, Oct 9, 2010.
  1. themountaintiger
    themountaintiger Read Only Funster
    Sep 27, 2009
    355
    63
    Lancashire
    Trying to save power when no hook up and have bought some LED lights. The lights that swivel 2, in dining area and 2 in bedroom (MR16's), ive got sussed and yippee control panel is showing that instead of 0.8 amps each they are now at 0.1 each amp each.
    My problem (if it is) is to do with the downlights which have a G4 in them. I found a G4 MR11 25 SMD
    on ebay to try and it does fit, but im unsure if the height of it, if touching the reflector semi dome would cause any potential problems. I appreciate that the dome must have heat reflecting properties as it is for Halogen bulbs, but is there any issue with LED's actually touching the dome area?? I bought just the one to try so dont mind binning it for a better solution before buying a set of 9 that I need.
    Hope this makes sense. Ive included a piccy, any help/advice appreciated...:Smile:
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,801
    There are different types of G4 LED - see illustrations Here - for different types of fitting.
    I'm sure Aten would advise which is right for your fitting.
    Graham
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,688
    5,837
    Mansfield,Notts
    :thumb:
  4. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    they have almost every type of led
    I agree with Grahm have a word with Aten they have most (not all) types of replacement led bulbs.
    They do not have the one for the American (Winnibago) wardrobe light.. this is a tube with metal prongs each end.. it has to be the original type replacement:Angry: know have tried to replace it .. have done all the others on my RV now and that is one lot of lights.
    But it does make a differance when you have done them to the battery drain.
    Bob:thumb:
  5. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    Thanks graham, I had been to the Aten web site and was undecided whether a flat one would have been better. There is one that is 23mm in diameter I was considering here , but bought the one I have as due to it being similar shape..
  6. scotjimland
    Jul 25, 2007
    28,936
    25,589
    You don't spend a lot of time in a wardrobe, so it's hardly going to be significant ... unless you haven't come out of the closet yet Bob ..:Laughing:
  7. slobadoberbob
    Jun 1, 2009
    6,159
    1,970
    still trying to get in it not out
    Even I cannot hop up into this one.. still trying to get in it.. It is one of those you never are really sure it has gone out when you shut the door.. but no we could not get an LED to switch in it's place.. that is the point Jim I was making.. not my sexual preferances.. .. still a blond, about 5'10" blue eyes ....and 25 years old would do nicely.. but Sue says I would not know what to do with it???:Doh: I would die happy I know that... :Blush:
    Anyway back to the wardobe... if I could only get in it and be sure it goes off:Eeek:
    Bob
  8. scotjimland
    Jul 25, 2007
    28,936
    25,589
    ah yes.. the old fridge light problem.. how do we KNOW it's gone out .. ?
    test the door switch .. :thumb: or drill a hole in the door to look inside :Doh:
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Take the bulb out :thumb: to be certain :Rofl1::Rofl1::Rofl1:
    terry
  10. scotjimland
    Jul 25, 2007
    28,936
    25,589
    the wood basher solution :Doh:
    :Laughing:
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Well you would not want to ruin the door by drilling it would you :Rofl1:
    terry
  12. scotjimland
    Jul 25, 2007
    28,936
    25,589
    fit a spy hole , same as a front door :Doh:
    [​IMG]
  13. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    That is sneeeeeky :Rofl1:
    terry
  14. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    the flat one would be better in my opinion.
    replace all mine on the kontiki with that type.
    www.ledbulbs4u.co.uk do a good selection.
  15. pappajohn
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    is this any good Bob?
    LED bulbs right hand side, second row.
    you remove ALL the gear tray from the existing lamp and replace it with this, simply connect to the existing switch.
    saw them at lincoln and they look fine.
    considering them myself but as i have 10 x twin tube fittings it works out rather expensive at over £220 :Eeek:
  16. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    Thanks pappa john thats the first web site ive seen which shows if you have one of these ie. the G4 halogen buy this circular one. Ive added the link for future motorhome funners who might have the same issue.. http://www.ledbulbs4u.co.uk/catalogue/Viewer.jsp?pID=199
    :thumb:
  17. pappajohn
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    the 9 led ones are much better than the 6 led version.
    i think the 6 led are 20w equivelent and the 9 are 25w.
    i used 25w in the main lights and 20w under the cabinets.
  18. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    hmm trying to work out if the 9 led ones will fit as they are 3cm diameter, whilst the 6 led ones are 2.3. now wheres mi measuring stick??
  19. caravanledlighting
    caravanledlighting Deleted User
    LED Lighting
    Hi,
    Maybe we can help please visit us at :spam: or send me your requirements to :spam: and I will sort out your needs.
    Chris
  20. scotjimland
    Jul 25, 2007
    28,936
    25,589
    have read the trader rules about :spam:
