Hand Brake on Burstner 748 - What Should I Expect?
Discussion in 'Motorhome Chat' started by StitchUp, Oct 16, 2012.
  1. StitchUp
    StitchUp Funster
    Mar 12, 2012
    884
    953
    Bridgend, South Wales
    The Burstner is a heavy vehicle and I'm not sure how effective the handbrake should be on such a heavy vehicle. Personally, I don't think it's effective enough.
    So, as the title says, how effective should I expect the handbrake to be?
    As the 748 is twin rear axle, what wheels does the handbrake operate on? Are there any common issues to look out for?
    My 748 is due an MOT late this month and I'd like to prepare it as best I can myself.
    Cheers Funsters :BigGrin:
    John
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,797
    6,057
    Mansfield,Notts
    Your hand brake will have to meet the same criteria as your every day car in term of performance specialist MoT equipment is reqd to obtain these figures,
    If your parking brake seems poor to you, it probably is
    usual reason for poor rear brakes is lack of servicing, many main agent garages do not see brake strip clean and adjust as part of their menu driven services, rather as a seperate job that has to be requested
    I suggest removing all 4 rear wheels, clean out dust, check for fluid leaks to rear brake cylinders, re set brake shoes and or pads, self adjusting systems can not be relied upon to correctly adjust pads or shoes, do it "Properly" not by just winding up the slack in the cable (For what its worth, doing that achieves nothing in terms of improving performance)
    But it does feel better:Doh:
    Geo
    • Like it Like it x 1
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    i believe the brake must meet at least a 16% efficiency.
    that, allegedly, equates to holding on a 1 in 6.25 slope.
  4. Chris
    Chris Funster Life Member
    May 5, 2010
    16,736
    36,841
    kent
    The handbrake on my Burstner is nothing special either. Regularly serviced but I don't know if they check these things properly.
    On steepish hills I am constantly holding it on the clutch if I have to stop.
  5. f6c
    f6c Funster
    Nov 7, 2010
    3,412
    900
    gloucestershire
    Find a dealer or garage that nows about tag axles:Wink:
  6. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Handbrakes on the tags are known for being bad - the older tag you have, the worse it is! Absolute hell to get an older through an MOT!
    Newer ones are better, as the manufacturer made the axles, whereas the earlier ones were indespension units.
    There is a 'fix' which involves oversize pistons - but to be honest, the result isn't really that much different! Get new system come MOT time and enjoy them working for a week or so.
    You can try a new cable if your lever is coming up particularly high - but try and save part buying until the MOT is due as you may have to do it all again then!
  7. rrusty
    rrusty Funster
    Dec 4, 2009
    86
    55
    Scotland
    Yes I agree, I bought my tag new 2010 and from new I had no confidence in the hand brake at all, and still dont.
  8. pappajohn
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    RV handbrakes, foot operated and located on the gearbox, are noted for being rubbish.
    But mine locked up and lifted the RV out of the brake rollers at last years MOT.
    this year i told him, 3 to 4 thousand quid if it rips the back off the gearbox and he wasn't testing it on rollers again, so he asked if it worked....."yes" I replied.
    he said "that'll do for me....it's passed." :Eeek::thumb:
  9. maz
    maz Funster
    Jan 26, 2011
    2,540
    2,177
    Out there somewhere
    Have now had two tag axle vans - both with rubbish handbrakes as supplied. However, massive improvement after taking them into the local truck garage where the mechanics actually understand what they're doing. Can highly recommend P&W Commercials near High Wycombe 01494 714714. Very reasonable charges too. :thumb:
  10. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,611
    3,429
    Telford, Shropshire
    "On steepish hills I am constantly holding it on the clutch if I have to stop."
    That's a recipe for a buggered clutch in short order. Firstly get your parking brake sorted, its not rocket science but as Geo says many garages don't do it as a standard part of service. Second, if your handbrake really won't hold your vehicle on a steep hill then use the footbrake not the clutch and engine.
    D.
  11. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    i find if mine wont hold on a hill i have little chance of getting the traction to set off again :Doh:
  12. StitchUp
    StitchUp Funster
    Mar 12, 2012
    884
    953
    Well, I took my Burstner for its MOT fully expecting it to fail on the hand brake which, in my opinion is dismal! It passed first time :Rofl1:
    After the MOT I had the garage replace all the brake pads on the 6 wheels, free-off and grease up the linkages where necessary and grease the axles (I've been told it's a good thing to do). The Burstner was delivered back to me yesterday with a cautionary note to bed the brakes in as they're not very effective just now!
    4 hours labour @ £40ph including delivery back to my home.
  13. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Where was that ?:BigGrin: I use Automaster in Brynsadler.
    Mike.
  14. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,109
    13,500
    Ramsey, Isle of Man.
    Ouch!!!!!!!!!!! That is one sure way to get rid of your clutch. If you ever had to replace a clutch, you would never 'ride' one again. I do not think people really understand what damage is done holding a vehicle on the clutch.
    Craig
  15. StitchUp
    StitchUp Funster
    Mar 12, 2012
    884
    953
    Hi Mike
    Just off J36 in Tondu. I've been using his services for just over a year and been more than satified with his work & honesty. http://www.rjdmotorservices.co.uk/find.html
  16. pappajohn
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    to my mind the H/brake test on the MOT is completely out of order.
    the hand brakes primary use is as a parking brake, not a stopping brake yet it is tested on moving rollers.
    it should be tested on stationary rollers to start then wind up the rollers torque until the wheels start to turn, or its lifted out the rollers, then use that reading as a pass or fail point.
    its secondary use is as an emergency stopping brake, but if it will hold at the correct static load it should also slow a vehicle down.
  17. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    if i remember correctly the rollers show if the handbrake drums are oval as the tester doesn't just rive it on to full.
    i feel this is more relevant now as modern handbrakes tend to use separate shoes and drums to the footbrake
  18. pappajohn
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    agreed, but it is still an emergency/parking brake...not a service brake.
    whether it is oval or round shouldn't make any difference...its primary role is to stop vehicle moving when stationary
  19. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,164
    14,018
    Heavan
    You should be able to do this in ne big burstner now then :thumb:
    [ame="http://m.youtube.com/watch?v=RzK19ppcB2E"]Skoda Felicia handbrake turn - YouTube[/ame]
  20. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,929
    9,024
    Lincs/Cambs border
    I must be the exception to the rule, as I am very happy with my handbrake performance.......as was the last MOT tester. :Wink:
    He tested the intermediate axle first, and as it was so effective according to the gauge, he didn't bother testing the rear axle. :Eek!:
    Annually, my brakes are serviced as Geo describes above, and the axles are greased at the same time too. The MH (on a 99 Ducato) has done 103K (kilometers) and is still on the original front pads and rear shoes. :thumb:
    Cheers,
    Jock.
