Halogen Bulb Replacment - Spotlight
Discussion in 'Tech/Mech General' started by Mark James, Jul 25, 2016.
  1. Mark James
    Mark James Funster
    Jun 1, 2016
    26
    13
    New Forest
    I really did try.... I wanted to do this small job on my own, no help, no guidance, just me with a little encouragement from the wife...FAILED
    I have an Ace Millano (2005) newly arrived saturday and had a great first weekend, one of my first jobs is replacing the halogens with LEDs, I have 4 spotlights that i believe are "Mini Spot Silver Sand10w halogen switched spotlight" I have managed to separate the internal glass housing from the plastic case by using a small screwdriver in the small gap but i am still unable to get to the actual bulb, i assume its something to do with the 3 small holes on the front of the unit ?
    Please please help me..
    Thanks in advance.
    Mark
  2. WillH
    WillH Funster
    Feb 9, 2008
    1,747
    1,471
    SW Scotland
    Need a picture.
  3. Manic
    Manic Funster
    Nov 4, 2011
    1,052
    1,181
    Uk
    I think they're the same as mine, as you say pop off bezel and from memory I think you hold the back part and rotate the bezel, the three holes are the tanges that hold the two together. I fitted 22mm 6 LED cool white bulbs in mine.
  4. Mark James
    Mark James Funster
    Jun 1, 2016
    26
    13
    New Forest
    These are the lights.
  5. Manic
    Manic Funster
    Nov 4, 2011
    1,052
    1,181
    Uk
    Yes same as been, I've checked and pop bezel off and then twist rear reflector, it's had to turn due to the rubber casket but if you look at the back of the bezel you can see the lugs and holes. The LED bulb I used was the rear pin type.
    • Like it Like it x 1
  6. Mark James
    Mark James Funster
    Jun 1, 2016
    26
    13
    New Forest
    Thank you Manic, The bulbs should be arriving any day so I will have another go when they arrive, thanks for replying.
  7. Mark James
    Mark James Funster
    Jun 1, 2016
    26
    13
    New Forest
    Thanks all for your help, the bulbs arrived and after your great advice on here have been fitted and
    are working perfectly, Thank you all very much.
    • Like it Like it x 2
