Hairline crack around showertray plug outlet - homemade solution? (1 Viewer)
Jul 18, 2010
1,201
3,013
Bournemouth and Gibraltar
Van Conversion
Since 2003
just wondered whether any funster can advise whether it is possible for a non-techy can seal up a hairline crack before calling out the "specialists"?
Is there any type of sealant available that could be easily applied and work well?
If not, I will have to call them in... have been given the name of Speedcoat as specialists in this field.
Thanks.
Feb 27, 2011
14,732
75,881
UK
Self Build
If you are looking for a quick bodge type repair? I removed my shower tray and reinforced it using fibreglass/resin on the back side. Doesn't give you a new looking repair on top but makes it solid enough so that the cracks don't spread any further and seals it from behind to prevent leaks.
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
If its just in the recess around the plug hole before the main flat area of the tray you can affect a repair by taking out the drain and fitting a white plastic washer underneath with plenty of Sikaflex under it, the washer needs to be the size of the recess in the tray.
A photo might help.
Martin
2657
Try Captain Tolleys Creeping Crack Cure,available mail order, I can't post the link as I am using a tablet but a search should find it. About £8 + postage....worth a try.
Gorsecover59
45
17
Jersey
Swift,Lifestyle 530l
new
Captain Tolleys is a waste of time.........if there is any movement at all the crack will open up.Thats why it needs support and then sealing.
scotjimland
2,314
9,990
A Woosh bang
I did a temp. repair using an two part epoxy adhesive..
rough it up a little and lay the adhesive into and around the crack.. not the prettiest of jobs but not seen under the shower mat..
a 'proper' repair was offered by Becks.. but I haven't had time (read cant be bothered) to take it to them,.. they said it took a whole day to do..
In times past I've also tried using the tip of a soldering iron to weld the crack..
Anthea M
Oct 18, 2015
9,501
165,143
Sheffield
Hobby
Since 2009
Thanks.
We had speedcoat come to our house and did a fantastic job as it was going to costs hundreds to replace the shower base and he matched the colour grey . It is slightly textured but much stronger than before.
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Since 2011, previously a tugger
I used fibreglass matting and resin on a 6 inch crack running along the gully to the drain. Once over painted white it hardly shows. Seems pretty strong now...time will tell.
scotjimland
2,314
9,990
A Woosh bang
can I ask how much ?
Anthea M
Oct 18, 2015
9,501
165,143
Sheffield
Hobby
Since 2009
We had it done in Sept 2014 and was on insurance but the company was Caratec ( it would have been £190 ) but to replace the shower and all that entailed would have been £500+ !!!
sciac2001
Jul 18, 2010
1,201
3,013
Van Conversion
Since 2003
I've just been quoted £325 by Speedcoat.
(A fellow mh owner had it done for that sort of price too.)
Thanks to all.
