Habitation lights (1 Viewer)
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
Dont know if some of you leccy teccys can help me out ?
I have a power isolator switch on control panel which shuts down power to habitation lights etc (as with many vans) however mine does not switch off fully,it leaves the lights very dim (low voltage). I can hear the EBL99 clicking as switch is operated. My thoughts is the EBL is at fault but before i start going through it all has anyone had a similar fault?
Tony
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Hi Tony!
I think your lights are simply following their owner's example!
Due to your snowboarding and emulation of Bradley Wiggins, they simply simply won't roll over and die!::bigsmile:
I hope someone comes along with a sensible answer mate!:thumb:
-Jon
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Tony
Has this just happened ?
If it's always done this I think someone has modified the wiring and some power is being fed from a none switched circuit into the switched one.
Possibly a bad earth somewhere.
jaygee
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
Hi Tony!
-Jon
Hi Jon
Glad you did not mention the DIM bit::bigsmile:
jaygee
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
It done the same thing a couple of weeks ago then cleared itself,
Now fault back permanently.
Thinking you may be on the right track,i shall start by isolating each circuit
43,323
49,422
I agree with Brians conclusion.
a bad earth and whatever else is on that earth is being earthed through the light circuit
jaygee
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
Now sorted,simple realy
I had a 12v rechargable torch pluged in,this must be faulty as it was back feeding when hab power switched off:thumb:
