habitation door hinge snapped today
Discussion in 'Tech/Mech General' started by roger hall, May 2, 2016.
  1. roger hall
    roger hall Read Only Funster
    May 2, 2016
    5
    4
    orkney
    had a scout about the internet but cant find any spares to replace it. the main part in the middle that broke off is riveted to the frame and the two lugs have an allen screw holding them to the door.
    total length 125mm
    where can i get one from?? any ideas please
  2. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    733
    4,723
    Chelmsford Essex
    • Informative Informative x 1
  3. roger hall
    May 2, 2016
    5
    4
    orkney
    email sent with copy of photo, hopefully they come with something. got a bit of a gap at the top of the door just now!
  4. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,752
    10,172
    o'learys also stock various hinges
  5. Arewethereyet
    Arewethereyet Funster
    Apr 21, 2016
    28
    122
    Bracknell, Berkshire
    Last resort, why not take the two broken bits to a local welders and see if they can TIG weld it back together, you might want to remove the plastic end caps first though, probably would only cost you a drink. (y)
    M
  6. Raybreck
    Raybreck Funster
    Nov 1, 2015
    118
    186
    Norwich
    Try Johns Cross 01580 881288 very helpful, got replacement hinge last year for our last van, a Swift Escape.
  7. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
  8. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    733
    4,723
    Chelmsford Essex
    This style of hinges fracture due to the hinge pin becoming corroded and bonding on to the aluminium body. The movement is then restricted and the Ali hinge fails through fatigue as it is being bent each time the door moves.
    The solution is to keep all hinges well serviced and lubricated, I suggest you check all the rest and give em some love and lubrication before the next fails. On my van all the locker hinges were very tight and showing signs of stress before I got some wd40 on them.
    Best of luck!
    • Like it Like it x 1
  9. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,690
    3,212
    East london
    They look similar but smaller than ours.. we had a problem with one last year and eventually got a replacement from trigano.
    Ours also had the flyscreen door on them and started to look like yours.. it back me stiffer and then seized. It's got a (I think) polyurethane center which jammed.. pita tbh
