Habitation door handle (1 Viewer)
Jan 31, 2016
1,902
3,377
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
The handle on the hab door is getting quite stiff and hard to use especially from the outside. Anyone know what type it is, as there's loads on the Hartal door handle (same problem) and don't know if Hymer use the same handle. Mines a T552CL 2009.
Or if anyone knows a cure I'd appreciate some advice, thanks.
Feb 24, 2013
13,083
101,446
Bolsover, Derbyshire
Hymer S800
not long enough
Not sure if this is your issue, or even the same handle, but we are having a problem that sounds similar
Typically if the handle is pulled before unlocking, or sometimes even when unlocked, it doesn't close
I have found if I ma firm with it I can push it back in, but do fear one day something will snap inside o_O
Lenny HB
53,421
149,945
On the coast in West Sussex
Hymer B678 DL
If it is that type and you can't open the door from outside there is an easy fix.
We need photos of the type of handle and the mechanism.
TheBig1
17,630
43,266
it needs a strip down and grease before reassembling. only use graphite powder in the key hole though
