Habitation Battery overheating
Discussion in 'Tech/Mech General' started by mike mcglynn, Dec 30, 2014.
  1. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,414
    5,695
    St. Helens MERSEYSIDE
    Hello, Can any kind person tell me why ? I have brought van home from storage after fitting new engine battery old one was dead :xangry: so I am on ehu to boost up the hab batteries with the onboard sargent unit, I have 2 x 110 amp ones which are about 3 years old and when I went into the van after about 18 hours on hook up there was a terrible pong from under the seat where the hab batts are located, one battery was cool and the other one was very hot to the touch so I have switched everything off and am waiting for things to cool down before I do anything. :xshout:
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    Turn off your charger NOW!
    It sounds like an internal short circuit and the battery could explode
    DO NOT use the 12v system until the battery is replaced.
    • Like Like x 1
  3. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    remove and get the battery replaced. ask for compo for wasting your time and leccy as well.
  4. pappajohn
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    Sorry just seen the last bit of your post.
    Regardless, DO NOT USE EVEN WHEN COOL.
  5. mike mcglynn
    Jan 6, 2008
    1,414
    5,695
    Hi Wildman its not the new battery its an older one the new one is for the engine bay.:xThumb:
  6. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    aha in that case replace BOTH hab batteries as there will both be goosed
    • Like Like x 1
  7. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,609
    22,750
    Narrfoook
    No one has mentioned the most dangerous aspect of all this ..
    PLEASE BE AWARE THE GAS GIVEN OFF IS EXTREMELY VOLATILE.. IT IS HYDROGEN !!!!
    By now yours will be pretty much clear, but for anyone who gets the pong of rotten eggs please make sure the area is WELL ventilated and for goodness sake do not switch on or off anything IN the van. Disconnect the EHU lead from the opposite end to the van
    I have seen the sides of building being taken out
    • Like Like x 1
  8. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,139
    15,089
    Leeds the one up North
    Yet Zeppelins proved difficult to blow up for a VERY long time despite being full of it :xlaugh:
  9. Badknee
    Badknee Funster
    Aug 25, 2014
    3,737
    16,463
    notloB
    It sounds like a massive overcharge but why just one??
  10. Jaws
    Sep 26, 2008
    18,609
    22,750
    Narrfoook
    Dunno about the Zeps Andy.. Before my time mate LOL !!
    But look at what happened to the R101 :(
    • Like Like x 1
  11. Techno
    Jul 28, 2010
    14,139
    15,089
    One knackered cell will drop the battery voltage even with two in parallel low enough to cause the charger to work at full output, most of that output will be converted to heat by the shorted cell thus depriving the other cells and the healthy battery from getting enough to cause a rise
  12. pappajohn
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    Last time i saw an exploded battery it was on a car.
    The whole top cover had blown off causing some serious denting on the bonnet and one side had blown out.
    acid everywhere.
    This had happened as the driver turned the key to start the engine.....must have put a severe load on an already faulty battery.
    • Like Like x 1
  13. Mr Ed
    Mr Ed Funster
    Dec 18, 2010
    559
    558
    Norfolk.
    When we had a similar problem we blamed the dog for a while,does the gas rise or fall?should we ventilate top or bottom."I don't mean the dog"________Martin:sick:
  14. Jaws
    Sep 26, 2008
    18,609
    22,750
    Narrfoook
    Rises.. There is a bit of a hint in there .. they filled Zeps and dirigibles with the stuff :xwink:
    • Like Like x 1
  15. scotjimland
    Jul 25, 2007
    28,934
    25,602
    It will most definitely FALL..
    Hydrogen is a colourless, odorless, tasteless gas.. lighter than air.. small amounts can be given off during normal charging.. what you smell is Hydrogen Sulphide..
    Hydrogen sulfide is the chemical compound with the formula H2S.
    It is a colorless gas with the characteristic foul odor of rotten eggs; it is heavier than air, very poisonous, corrosive, flammable, and explosive.
    • Like Like x 3
  16. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    997
    1,763
    Essex
    Don't attempt to disconnect the faulty battery until the motorhome has been well aired, as there's a high chance you'll get a spark.
    Disconnect the EHU, then leave all windows and doors open.
    • Like Like x 1
  17. Jean-luc
    Jean-luc Funster
    Aug 15, 2014
    104
    69
    I had a similar situation last year.
    First thing I noticed was the panel showing about 3 amps charge going to the hab batteries when it should have dropped to zero.
    On investigation I found one of the two hab batteries a little warm.
    I turned off the charger and next day disconnected the faulty battery. Later when funds became available I replaced both on the assumption the the other probably wasn't far behind the first as both were originals fitted in 2005.
    An interesting aside is that the failed battery was a second battery supplied by the dealer as the vehicle was originally fitted with only one by Rapido. It was also the furthest away one which leads me to think that there is something to the recommendation that multiple batteries should connected as show below Parallel Battery Connection.gif
  18. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,544
    2,558
    Trowbridge
    Wouldn't that give you 36v
  19. Jaws
    Sep 26, 2008
    18,609
    22,750
    Narrfoook
    No, 12v.
    You would have to connect the batteries in series ( + to minus on the next one and + to minus again )
    All the -ves are joined as are all the +ves so 12v output
  20. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,544
    2,558
    Trowbridge
    Ok.. I'm a novice so will read with interest.. why is there any difference between the set up suggested here and connecting all the batteries in parallel and then connecting to the system?
