habation and electrical testing
Discussion in 'Motorhome Chat' started by dm73779, Jan 26, 2012.
  1. dm73779
    dm73779 Read Only Funster
    Jan 26, 2012
    5
    redditch
    How often do you have a habitation or electrical check?
    I know these tests are not legally required, but would you advise them to be done and if so how much should i be paying?
    regards
    dave
  2. stcyr
    stcyr Funster
    Apr 11, 2011
    1,680
    1,114
    Normandie
    Hi. Depends on one's level of expertise ... Personally, the only professional one I've ever had done was the freebie one when we bought our present MH. Everything they did I could've done myself. In fact they told me they had a problem getting the water boiler to work and that they'd have to get the Truma guy in which could take a week. I told them that if they removed the vent cover it would probably work. They removed it and it worked. Same with the Truma gas heating: they couldn't get it to go more than a minute. I pointed out to them that I'd noticed the 'chimney' laying in one of the lockers and that a cover had been fixed over the flue. ...
    Some companies doing hab.checks exclude certain things like the fridge. In my view that is one of the things not everyone is familiar with. Damp problems can be detected simply enough. Best thing is if you are not confident have it done professionally - and hope they know what they're doing. Go on recommendation if you can. :thumb:
    • Like Like x 1
  3. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    • Like Like x 1
  4. dm73779
    Jan 26, 2012
    5
    redditch
    I am quite suprised when people say they can do it themselves. How do you pressure test the gas system to check for leaks without special equipment? likewise how can you check the gas emissions coming from say your fridge without the analiser?
  5. motorhomewave
    motorhomewave Funster
    Jul 17, 2009
    130
    48
    Lowdhams
    Just recieved a letter from Lowdhams asking me to book a habitation check since it will be due one in March. Further down the page it quotes " We would ideally like the vehicle for 7 days to give us flexibility in our work schedule" They must be living in another world ! 7 days for a check that takes approx 1 hour I don't thinks so.
    We had the first free check with Lowdhams, ever after we use a qualified mobile engineer who comes to us does the check, fixes anything we need doing, orders parts if needed and is cheaper than the the dealer, No contest.:Eeek:
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    hi and welcome to the fun from your reply you obviously would know what you are talking about however, a gas leak will result in a smell anyone could detect and an empty bottle. Providing the fridge and fire burn with a blue (not yellow) flame and both work then ok Emmisions are vented outside of the motorhome and the carbon monoxide detector inside would soon go off if emisions were bad and somehow leaking into the van. A damp detector is only a few quid off of ebay but your eyes and nose are probablly a better indicator. If you are unsure then by all means go for a check it will be around £100 for less than an hours work and some checks are more thorough than others. For an initial purchase of a secondhand van it could be a good idea to uncover and hidden problem whilst you have time and warrenty to get them fixed. There are a number of excellent engineers that are members of this forum, Dave Newell, Dave Evans, CLS (mobile), Ash (mobile) etc all of whom wiill carry out a full and proper inspection/service. They are all registered TRADE members.
  7. scotjimland
    Jul 25, 2007
    28,934
    25,602
    A simply way is to install a pressure gauge on the LP side of the regulator.. some RVs have a gauge mounted inside the van to monitor gas pressure.. Gaslow systems have one as well.
    Method.
    * Close all appliance valves and bottle valve (if a tank, the outlet valve). This 'locks' the gas in the system.
    * Watch the gauge.. it should maintain the pressure for some time.. if it drops quickly you have a leak..
    It won't hold the pressure indefinitely as a very small amount of gas can leak around control valve stems on the cooker etc .. but if it holds for 30 mins or so.. no problems.
    For gas appliances as Roger said..
  8. mikkidee
    mikkidee Read Only Funster
    Aug 1, 2010
    289
    227
    Malton,North Yorks
    Don't suppose he lives near the York area??
    Mike:Smile:
  9. motorhomewave
    Jul 17, 2009
    130
    48
    We live in the Harrogate area but the engineer is from West Yorks...Mathew Bell,
    e-mail, info@yorkshirecaravanservices.com
