Hab Door lock problem (1 Viewer)
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
The lock on my door is a Zadi type G18A182 and the problem is the exterior handle turns a square shaft which is attached to a striker arm which operates the lock.
The striker arm is plastic and has snapped on the square shaft. so the door cannot be opened from the outside.
I have tried gluing, but not strong enough.
I have tried numerous places but no luck. The broken piece is only a 10p part, but if I have to buy the outer assembly so be it.
Can anyone help as the only way into the van at the moment is though the cab, as once the door is closed it self locks.
Malc
TheBig1
17,613
43,149
anyone with basic metalwork skills could make a replacement from brass or aluminium. the replacement would be so much stronger:thumb:
Jim et Lou
216
119
Sheffield
Coach built
I am new to this
I had the same problem on my Laika. I finally found this firm in Poland and bought the whole handle for £15:99 including postage here in the UK they wanted anything from £55 to £111. They may not have the one you want but is worth a look.
:thumb:Broken Link Removed
TheBig1
17,613
43,149
Just made a drawing for my local metal worker.
Malc
even better you could give him the broken parts so he can take measurements and compare directly
