Hab Door Bin (1 Viewer)
May 23, 2012
373
342
Anglesey
Rapido 666f
I have a 2014 Autotrail and the habitation door bin has broken, its the door panel that has cracked are the bin pins locate. Has anyone else had a similar problem and is there a fix. Thanks in advance.
43,320
49,406
Easy, if you can remove the inner door panel.
If not it may need more thought.
As Techno said....pictures ?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Door liners usually crack due to flexing and lack of strengthening. Typical of motorhome converters making stuff look good enough that you'll buy it but without considering its usage and longevity.
Think in terms of aluminium strip sikaflex rivets or anything else you can do on the inside that won't be visible
Southampton
522
318
Hampshire
Since 2009
I have had exactly the same problem on my 2013 Autotrail. We never used the bin anyway so just took it off. I can't see an easy solution so we just "binned" it. Now looking for one of those hanging tidy thingies in its place.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Rapido door pocket lids all crack eventually, mine did in two places but I've riveted a piece of Ali angle inside
Techno
Jul 28, 2010
15,475
20,756
May 2010
If it were me I would glue a strip of suitable material inside that can be re drilled then fill the missing material of the door skin
Probably best drilled before glueing in place
zac
2,600
1,851
Basingstoke
Rapido A CLass 10000
since 2013
Won't that come under warranty, i think ours is 3 years from new although something happens with the 3rd year but it is still covered just a different way of claiming. If it cracked already then i would angle on not fit for purpose unless there is another reason it broke.
Mar 10, 2016
558
617
Scotland
A Class RMB 750HE
Three years and counting, 30 years a tent tower.
I thought this was another Isis or taliban thread :)
Jim do try and keep up.. They threw Bin Liner out of a Huey somewhere over the Indian Ocean:):)
