Hab aircon, service or maintance?
Discussion in 'Motorhome Chat' started by Mousy, Mar 20, 2016.
  1. Mousy
    Mousy Funster Life Member
    Sep 13, 2013
    2,141
    7,156
    Sa15 2DG
    we have both cab and air conditioning systems in our Hymer, do we need to carry out any annual service or maintance to either of them? And if so where would we go? We are in west wales.
    Many thanks
    • Useful Useful x 1
  2. The Old Man
    The Old Man Funster
    Jan 23, 2016
    449
    3,112
    Wales
    I think Kwik Fit do A/C services and recharges, but not sure if they would touch the habitation one.
    Back to a Hymer dealer would be a safe bet.
    • Like Like x 1
  3. Mousy
    Sep 13, 2013
    2,141
    7,156
    Sa15 2DG
    Thanks, so it is something that needs attention? We've had the van for a year but it's 8 years old. What is a recharge?
    I'm blond with a nic name of "user error" so go gently with me!
    • Like Like x 1
  4. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,703
    11,858
    Plympton, Devon
    There is a refrigerant in them which can leak out over time. It is routinely checked and recharged when cars are serviced.
    You might find a mobile air conditioning engineer locally who will pay a house call.
    I know car air conditioning systems should be run regularly to maintain the seals so I guess the same applies to hab systems, in other words don't just let it sit idle over the winter. :)
    • Like Like x 1
  5. Mousy
    Sep 13, 2013
    2,141
    7,156
    Sa15 2DG
    Oooppps:eek:
  6. John Laidler
    Jan 9, 2013
    8,703
    11,858
    Plympton, Devon
    I've not heard anyone mention this with regards to MHs but it is certainly advised for cars so worth doing.
    • Like Like x 1
  7. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,528
    12,685
    Bolsover, Derbyshire
    Hello Dawn, is your habitation air con roof mounted or one of the sealed Dometic jobs like we have?
    edit - just remembered your post from yesterday, where you sent Martin up on to your roof, been back and looked at the photo, you do not have a roof mounted system
    now we both need to answer the same question, but we almost certainly both have the Dometic mains powered only air con cell, will look at my books and see you at Chester hopefully with the answer (y):)
    • Like Like x 1
  8. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,152
    6,244
    UK
    Air con systems do require service when required. Simple test is this, run them both on the coldest setting. Do they cool down and blow out cold air? If not then they'll need a simple recharge. It's not hard to do and most people think it's a complicated affair, but it's not.
    It can easily be done DIY, you just need to ask the right people who won't charge the earth, so be weary of prices. Halfords do a recharge at very reasonable rates (for the cab, not sure about habitation if it's separate). They also supply a purifier that's easy peasy to use, just turn on aircons fully, put on recycle, pop the can and vacate while it purifies the system.
    No harm in asking if they can do it all for you. I do all my own and saves £££'s.
    Good luck and hope you get it sorted :)
    • Like Like x 2
    • Informative Informative x 1
  9. Wickolad
    Wickolad Funster
    Sep 10, 2013
    480
    518
    Wickersley
    Recharge is basically recharging the system with refrigerant. I believe it is removed mechanically from the system and weighed and the correct amount then put back in. You can usually tell if this needs doing if the air con is not getting cold or is less efficient than it was.
    The only thing I have tended to do with the cab air con is use a air con cleaner / freshener, you can get a spray tin from halfords, you spray it into the air vents and put air con on full recirculation, get out of cab and leave it running for a while. It kills any bacteria in the vent system and freshens it up as sometimes it can smell a bit musty.
    If your system isn't working as it used to, then it may well need recharging. If you search google for automotive air conditioning engineers there should be someone in your local area.
    Haha, you beat me to it PP bear, faster typing :)
    • Like Like x 1
  10. Mousy
    Sep 13, 2013
    2,141
    7,156
    Sa15 2DG
    Thanks all as usual for some comprehensive Funster replies, I'll have a go at running the hab con but I've got a feeling it needs doing.
    @DavidG58 looking forward to seeing you both at Chester...wouldn't it be great if we need aircon there? fingers crossed its dry, 30 degrees might be too optimistic
    • Like Like x 1
  11. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,528
    12,685
    not been to my MH yet to look at books, but did Google Dometic air con motorhomes, even higher up the list than Dometic came Vanbitz :) they fit them, both roof type and in locker types like ours, does yours have a remote control and vertical grill outlets?
  12. Mousy
    Sep 13, 2013
    2,141
    7,156
    Sa15 2DG
    Yes to the remote control. Not sure about the grills, I'll just finish the ironing and pop out for a pic.
  13. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,528
    12,685
    save it for Thursday (y), we are coming over via Travel World to get our gold plated headlight (based on price alone) changed, I will check with them to see what needs doing and how much it costs :)
    • Like Like x 1
  14. Sheddy
    Sheddy Funster
    Oct 20, 2010
    903
    3,422
    Burry Port South Wales / Benidorm
    These folk are based in Pembrey, we have used them for hab service and the price and service was good.
    http://www.leisuremedic.co.uk
    Ed
    • Like Like x 1
  15. Derbyshire wanderer
    Derbyshire wanderer Funster Life Member
    Mar 30, 2014
    461
    758
    Derbyshire
    Cab
    Apart from the pollen filter (if there is one) there is nothing to service apart from the drive belt replacement that should be picked up on an engine service if it is worn out. This is assuming that it does provide the cold air when switched on.
    The purifiers are to clean the evaporator which can harbour bugs and they basically sterilise the insides. Absolutely no need to pay anyone to do this for you as the instructions are on the tin and it is just operate it as instructed while injecting the spray through the inlet vents (the pollen filter will need taking out if it has one).
    Habitation
    This one has no belt so assuming it works ok, I would just use the cleaner on it.
    • Like Like x 1
  16. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    4,820
    9,045
    Lorca,Murcia,Spain
  17. Derbyshire wanderer
    Mar 30, 2014
    461
    758
    Derbyshire
    As I understand the regulations, the maintenance elelement requiring certifification only applies to trucks over 3.5t, trailers and commercial equipment. Mobile air con systems in cars and the like only requires certification for recovery of the gas etc. This is a simplified answer but the point is that cleaning the system with the disinfectant spray does not in any way break the law.
  18. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    4,820
    9,045
    Lorca,Murcia,Spain
    It is badly written.Any work on a refrigeration system requires a person to be certified. On any system that has lost its gas the first requirement is that the Leak is found & rectified, before ANY refilling is attempted. That is the first requirement under the regulations. Any attempt at refilling without leak testing is
    2 years & a 50k fine.
    We all know that lack of use of vehicle A/C systems will lead to the compressor seal drying out & the resultant loss of gas from the system. It is illegal to refill without rectifying the leak.
    I'm merely pointing out the regs ; not that anyone complies with them on car systems.
    You are correct up to a point with your last statement excepting that if it is an older vehicle that has a system still containing any of the Freons that were phased out years ago, & yes there are still vehicles with R12 in , it is illegal to do ANY work on the system whatsoever without the refrigerant being recovered & changed for a drop-in replacement. The Uk went a bit overboard in applying regulations years ago & it is a pity that many other countries didn't have the same outlook & time frame.
    • Like Like x 1
  19. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,528
    12,685
    just a prompt to remind me to see you about this over the weekend, but where I thought we had Dometic we actually have Truma Saphire, still have no idea about servicing it, but having the right model gives us a better chance :)
  20. ChrisL
    ChrisL Funster
    Apr 26, 2015
    20
    14
    Bedfont
    Not sure about habitation a/c but vehicle a/c should be recharged every two years, this is because the system contains a lubricant for the compresor and just like your engine it needs changing periodicaly, as part of the recharge process the system will be pressure tested for leaks before being refilled. My experience with kwikfit was not good so i went to an a/c specialist, which was altogether a better experience.
    • Like Like x 1
