Gushing grey water
Discussion in 'Motorhome Chat' started by DavidG58, Jul 14, 2014.
  1. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    Bolsover, Derbyshire
    Hello all, not the usual grey water thread, but we do indeed have a gush, or we did until the tank ran out
    Luckily we were home with a hose connected to drain
    I can not now close the valve, it is connected via what looks like bike hand brake cable kind of linkage about 2m long
    The handle I normally pull to open the valve will now push in but springs out, even when the handle is pushed in the valve is still open
    Those that know me already know I don't 'do' when it comes to fixing things, but I might actually have a go at this, presuming somebody tells me what I need to buy and how to fit it :whistle:
    Actually already thinking it will have to go to a workshop, unless anybody thinks I might be something simple that I can fix :D
  2. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,415
    5,669
    Guisborough
    Hi David
    I don't know your system but it sounds like there should be a spring that isn't there anymore, go on get in there and get dirty you might even fix something.
    When it worked "proper like" did you have to hold the handle out or did it lock I some way.
    Martin
  3. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    Thanks Martin
    The handle pulled out to open the valve and stayed there by friction, pushing the handle back in closed the valve (or used to at least
    Logic would say it has become disconnected at the valve end, or broken in that same general area
    David
  4. MrsBB
    MrsBB Funster
    Jun 14, 2014
    76
    43
    Derbyshire
    Oh no...... Least I'll know what's happened in future! Hope you manage to sort it.
  5. funflair
    Dec 11, 2013
    5,415
    5,669
    Guisborough
    When you push the handle in and it springs back out suggests it's still connected to something just that something is now too tight to move, as in too tight or has not got the help of a spring was my thinking, I could be completely wrong.
    Sure somebody will be along who knows more than me.
    Martin
    • Like it Like it x 1
  6. BreweryDave
    BreweryDave Funster Life Member
    Aug 10, 2011
    1,708
    3,906
    Torre Del Mar - Malaga
    Shoulda left it at SMC today and bought a decent van:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    • Like it Like it x 2
  7. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    bump
    I should have added that we have a Hymer
  8. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    Have you tried the first thing when most things stop working..............A good spray all round it with WD40.
    Try spraying all around the valve and pushing the bit the cable attaches to
  9. JJ
    JJ Funster
    May 1, 2008
    14,904
    26,742
    It's God's way of saying he doesn't mind a bit of washing up and showering water being spread on the land he made for us...
    JJ :cool:
    • Like it Like it x 4
  10. wasp
    wasp Funster
    Dec 21, 2008
    2,733
    1,072
    Mansfield
    Have been underneath to ave a look you
  11. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    I have given it a good looking at, but not been underneath, I can see where the cable runs to at the outlet from the grey tank where the valve must be situated
    I will get under tomorrow and have a closer look and maybe a prod, but I am more likely to make it worse than fix it, unless I get very lucky
  12. timdownieuk
    timdownieuk Funster
    Apr 9, 2013
    618
    329
    Ayr
    If it's operated by a Bowden cable it sounds like the cable outer has become detached at one end or the other or the outer is stretched/unravelling. I could be just that the valve is sticky and the cable isn't "man enough" to push it back closed. Bowdens work best in tension application although a rigid cored one can push as well as pull.
  13. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,782
    10,198
    they tend to be similar in operation to a bike brake dont they? with a return spring to close the valve as the lever is pushed across. it may just be the spring has popped off, or the shutter on the valve is jammed
  14. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    If it is a blade valve, like an RV, these often stick and might need replacing every ten years or so. The US parts are pretty easy to replace, but no idea how European equivalents would be. Normally, a sudden sticking is due to foreign matter (i.e. toilet paper or other foreign body) blocking the blade from fully closing. In this case, you may be able to dislodge the blockage by using a high pressure hose up the outlet.
  15. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    Thanks for that, I think it will be a blade valve, but probably only a small one compared to RV's, I think the pipe size is 1.5 or 2", it is only grey water, we have a separate black tank
    But thinking about it we had added a potion to clear the grey tank before leaving site today, that suddenly makes sense, maybe a lump fat has come loose and got stuck at the valve, I will refill water tomorrow and run hot water through
    I will also see if I can see what is fixed to what tomorrow and hope to push the valve closed from outside, the pipe has a 90 degree bend near the end that will make jetting quite hard
    David(y)
  16. Chris
    Chris Funster Life Member
    May 5, 2010
    16,742
    36,880
    kent
    Just leave it open like I do.
    The amount of time you save not having to faff around emptying it you wouldn't believe.
    It leaves more time to look for somewhere discreet to dump the cassette.
  17. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    I have taken a few photos but can only upload this one, all the other say file too big, I have now identified that the cable outer is detached as suggested by Tim (thanks), I have also discovered the whole thing looks to be a massive overkill
    The cable goes about 1m in total, including quite a sharp bend, it looks like a real job to change and part probably only available via Hymer
    So what do you think to me cutting the pipe in the top photo between the bracket and the 45 degree bend, then fitting a decent ball valve, it is quite easy to get at to fit and then use, seems a much better way to fix the problem, if it ever got blocked I would have a half chance of poking something in from the outside
    Not too sure about the pipe size, looks to read 1"1/4 and 40? mm, I know from work that metric / imperial are measured internally and externally, so is it 40mm OD and 11/4" ID?
    Anybody got any better ideas about this?
  18. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
  19. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    I have found that the outer is detached at the handle end, so form your knowledge is that mendable or will it need a change of cable
    See above post, to me it looks a big job to change the cable and it will still be a bad way to do the job IMHO, unless the cables can be mended it would then probably be a quicker fix
    David
  20. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    Thanks Terry
    It is nice to have your approval, seemed like a good idea when I looked underneath, no idea why Hymer did what they did
    Ordered valve, hope it is 11/4", I'll be up to see you with MH and valve in hand :D(y)
    David
