Gross Weight (again)
Discussion in 'Motorhome Chat' started by gibbon, Jul 25, 2014.
  1. gibbon
    gibbon Read Only Funster
    Feb 25, 2013
    308
    326
    Shatterford
    Having read all the scary stories about being stopped & fined whilst abroad I decided to check my plated weights. Auto Trail state my Cheyenne 634 is rated at 3400 kg. No problem I assumed, the previously owner stuck to this & travelled all over Europe without any problems. I'm thinking now that he was lucky & was never pulled over & checked.
    I've gone all over the van (a 2000 year model) and there is no plate for autotrail stating the maximum as 3400 kg. The only plate is the Fiat one on the slam panel under the bonnet which states the max as 3200 kg. So I've been driving thousands of miles technically almost 200 kg overweight as far as I could evidence if stopped by the police!
    Also, there is nothing on the V5 regarding max weight, it's been left blank.
    I reckon Autotrail have not plated the weight or told the DVLA back in 2000.
    I phoned Autotrail giving all the details of my van, I had the build serial number but I never got far enough to have that conversation!
    The gentleman I spoke to confirmed the correct weight as 3400 kg but in the same breath said that as my van is 14 yrs old it predates the present company and they would not supply a plate due to not having the paperwork to evidence it (but he was able to confirm the weight!).
    He told me where the plate should be. On the passenger door pillar(1st place I looked).
    So that was me stuffed!
    I've just sent off an enquiry form to SvTech to see if they can help me out . Ah well, rant over, feel a bit better now:)
  2. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    On the plate under the bonnet, it should also give your axle max load weights. Adding them together can be helpful in explaining to police type peeps if stopped. My gross is 3200, (Hymer Camp), but the axle load totals 3300. V5 is of coarse 3500. :)
  3. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,683
    5,883
    Guisborough
    So doesn't that mean that you can't load more than 3200, surely the V5 is wrong.
  4. gibbon
    Feb 25, 2013
    308
    326
    Shatterford
    My axle weights total 3440 kg so that could be of some help if stopped.
    Thanks for that(y)
  5. gibbon
    Feb 25, 2013
    308
    326
    Shatterford
    Surely your not suggesting that the mighty DVLA have made a mistake:rofl::rofl::rofl:
  6. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    The only weight stated on my V5 is 3500.
    The original unladen weight was 2800, max weight WAS 3100, (but at some time in the past that has been changed to 3200). Front axle 1600, rear axle 1700, total=3300. Yea I know, but hey.........
  7. vwalan
    vwalan Funster
    Sep 23, 2008
    7,695
    3,970
    roche cornwall
    dvla will have been told the weights by someone else.
    but most v5 dont show weights . be nice if they did .
    should think sv tec can sort it . they may need to inspect the vehicle .
  8. Puddleduck
    Puddleduck Funster Life Member
    Jan 15, 2014
    6,782
    14,629
    Scottish Borders
    Our owners manual says 3300 but the plates and V5 say 3500.
    We had it weighed (fully loaded and with full tanks and passengers) and it was 3100. that was before we had the bikes.
    We will have to be careful not to accumulate junk.
  9. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,086
    3,483
    Eastbourne East Sussex
    Your GVW is the important one, and you would be deemed to be overloaded even if neither of your axle weights were exceeded.
  10. gibbon
    Feb 25, 2013
    308
    326
    Shatterford
    That's why I'm hoping SvTech can sort it for me(y)
  11. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,069
    12,424
    Plympton, Devon
    I dont believe you can't add the two axle weights together and come up with a new gross weight. Each weight is the maximum for that axle but the combination of both axle loads cannot exceed the gross.
    • Like it Like it x 4
  12. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,301
    3,104
    Kendal, Cumbria
    That's correct - you can't. Individual axle allowances accommodate uneven loading (or indeed the build of the vehicle) and to be legal neither axle should be carrying more that its plated maximum AND the total vehicle weight must not exceed that marked on the plate.
    I wouldn't expect the converter to attach another plate after the motorhome body was attached because legally it would have to repeat the information on the base vehicle manufacturers plate. The Police or VOSA will only look at the base vehicle manufacturers plate.
  13. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    [QUOTE="tonyidle, post: 1066489,
    I wouldn't expect the converter to attach another plate after the motorhome body was attached because legally it would have to repeat the information on the base vehicle manufacturers plate. The Police or VOSA will only look at the base vehicle manufacturers plate.[/QUOTE]
    Incorrect, my van has THREE plates, one from Fiat, one from Adria & one from SV Tech. All show different weights.The police & VOSA will go off the plate with the gross which matches the vosa records (which should match the V5) & then use the axle weights from that plate,
  14. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,464
    25,469
    Planet Zog
    Mine too.....
    • Like it Like it x 1
  15. DP_JAY
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    Your Pilote has a plate from Adria?
    :rofl::rofl::rofl:
  16. Puddleduck
    Jan 15, 2014
    6,782
    14,629
    Scottish Borders
    Mine has two plates, one from the converter and one from the original base vehicle. The weights are the same and match the V5.
  17. DuxDeluxe
    Jul 10, 2008
    9,464
    25,469
    Planet Zog
    Got it from a dodgy guy who would only accept cash. Should I be worried? :blush:
  18. DP_JAY
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    No, not at all.
  19. DP_JAY
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    Ask Dux nicely & he'll introduce you to a dodgy guy who can fix that :rofl::rofl:
  20. gibbon
    Feb 25, 2013
    308
    326
    Shatterford
    Got my plate(sticker) & covering papers from SvTech today.
    According to their quite comprehensive instructions if the taxation class is not changing & the revenue weight is blank on the V5 then I don't have to inform DVLA , which in turn means they don't have to lose all my paperwork for me.
    RESULT!
Similar Threads
  1. GWAYGWAY
    7
    312
  2. Mickey1
    299
    12,716
  3. PJA
    10
    326
  4. EX51SSS
    22
    1,029
  5. sillybug
    469
