Gross vehicle weight / payload (2 Viewers)
Sep 17, 2017
5,453
10,173
Birmingham, UK
A-Class
Isn't the question here what's the difference between the 3.3t and 3.5t chassis? Even if you aren't going to hit load limits, is there a reason to go one way or the other? Does the 3.3t ride better because it has more compliant springs?
My 2007 conversion was a 3.3t. Although we weren't technically overloaded, it rode pretty low at the back until I replaced the knackered bump-stops with added semi-air suspension. That might just have been that the springs were tired though.
Jan 17, 2010
262
348
Northants
Bailey Approach740SE
Since 2006
I think that its to do with unladen weight and speed restrictions. If its under 3.05tonne then there are no speed restrictions ie same as a car, if using the maxi chassis takes it over 3.05 tonne then you get 10mph knocked off the speed limits. You can then uprate to 3.5 tonne on the lighter chassis but the unladen weight will still be under 3.05 tonne and no change to speed limits.
Thats my guess anyway
Minxy
32,646
66,532
E Yorks
Carthago Compactline
Nope the maxi chassis doesn't take it over 3.05 tonne, well not on the ones we had anyway.
Aber Kid
3
4
Autotrail TrackerEKS
I've just bought an 08 Tracker.
I'm mystified by all these weight topics!
The FIAT plate in the bonnet states gvw 3500kg.
The Autotrail handbook figure is 3300kg. They state the unladen weight is 2915kg.
Just received the DVLA registration doc, it says 'Revenue Weight' 3300kg.
Who's more right here?
My bet is FIAT with 3500kg.... However, I notice that a substantial chassis extension attached to the rear end of FIAT's chassis supports the rear end of the mh. So maybe this accounts for the 200kg difference...???
HELP !!!
SandraL
1,373
985
Somerset
Hymer b694sl
HELP !!!
Fiat as manufacturers of the chassis put the first plate on.
The motorhome manufacturer may decide the finished motorhome should be plated higher, lower or the same as Fiat.
They will add a 2nd plate detailing their weights. It may not be next to Fiats plate.
The latest plate takes precedence.
You might decide to uprate van to 3500 or above.
To do so you will need a dvla approved engineer to agree and provide a plate and certificate.
Minxy
32,646
66,532
E Yorks
