Grey water tank cleaning
Discussion in 'Tech/Mech General' started by Chrisy, Mar 25, 2016.
  1. Chrisy
    Chrisy Funster
    Jul 10, 2014
    138
    42
    Cheltenham
    The tank is under the floor with no access. Smells coming through basin and sink plug holes. Any recommendations please as to best cleaning solution to use bearing in mind I can only pour it down the sink.
  2. Al-Di
    Al-Di Funster Life Member
    Mar 15, 2014
    1,110
    4,575
    prestwich
    soda crystals in hot water, half fill tank then go for a drive with lots of bendy roads & drain, may need to do a couple of times,(y)
  3. Sheddy
    Sheddy Funster
    Oct 20, 2010
    979
    5,099
    Burry Port South Wales / Benidorm
    Cheap Lidl coke, pour a few large bottles in empty tank take it for a drive to swill it about, flush it with clean water after. (y)
    Ed
    • Useful Useful x 1
  4. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,969
    13,408
    East Sussex
    • Useful Useful x 1
  5. Hils and Glenns
    Hils and Glenns Funster
    Aug 13, 2015
    532
    1,861
    N Yorks
    Cap full of Zoflora?
  6. StitchesnFluff
    StitchesnFluff Funster
    Oct 18, 2014
    1,276
    546
    Salisbury
    I use a small amount of the elsan stuff into the waste pipes via sink holes each time empty out & fill up the fresh water. That seems to keep smell bugs away whilst travelling.
    In between travels leave waste open so it drys.
    If already smelly cheap Coke does work.
  7. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,910
    9,450
    Tropical Bar,Benidorm.
    We use the cheap coke method and find it works as well as the proprietary cleaners.
  8. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,125
    3,541
    Eastbourne East Sussex
    The cheap coke from any supermarket. For some reason the one with sugar in seems to work better than the diet version. Bung in about 6L putting it down all the drains, nice bumpy drive, leave for a few hours and drain. Gets all sort of muck out.
    • Useful Useful x 1
  9. sedge
    sedge Funster
    Jul 7, 2009
    4,659
    4,220
    Nr Jct 3 M6
    Urban drives are ideal for the cheap coke treatment, on roads you normally avoid cos of all the speed bumps!!
  10. Chrisy
    Chrisy Funster
    Jul 10, 2014
    138
    42
    Cheltenham
    Thanks all. It will initially be a cheap coke treatment. No problem finding a bumpy road, around here it would be hard to find a smooth one!. Then regular Dish'n'treat will be the plan.
  11. Robert Clark
    Jul 12, 2014
    6,969
    13,408
    East Sussex
    Once you've started using the Dish'n'treat you'll ever have a smelly tank again - sorted !
