Grey water indicator
Discussion in 'Motorhome Chat' started by Jerrymjj, Apr 18, 2014.
  1. Jerrymjj
    Jerrymjj Funster
    Apr 3, 2014
    93
    27
    Alton Hants
    Having just returned from our maiden voyage in our 2006, Autotrail Tracker SE we are delighted with the experience and look forward to many such ventures.
    Our only minor niggle was that the waste water indicator stayed showing 0% for the whole of our three days away despite going through a full tank of fresh water, most of which would have ended up in the grey waste. Is this likely to be a failed sensor? I am reasonably competent mechanically so would be happy to try and replace it myself if possible but don't actually know where the tank is...
    And while I have your rapt attention, could anyone enlighten me as to the whereabouts of the external awning light switch? Hunted high and low but can't find it...
    Many thanks, Jerry.
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,874
    23,573
    Narrfoook
    Canna help with the switch but the grey tank indicator would proly, as you guessed, be a failed sender unit.
    A lot of them are simply a series of reed switches in a sealed tube.
    The tube has a magnet set in a plastic ring around it that simply floats up which activates the various reed switches.
    Lost count of the number I have fixed over the past 7 or 8 years !
    Also, pretty common, is the float thing simply getting stuck ( whish is a reet pain in the bum sometimes :Angry: )
  3. maz
    maz Funster
    Jan 26, 2011
    2,549
    2,173
    Out there somewhere
    Waste water indicators are notoriously unreliable. Mine used to set off an alarm telling me the waste tank was nearly full - at random moments, even when the waste valve was open and the tank was empty! :RollEyes: So I just disconnected it.
    Don't know your particular van but awning light switches are quite often incorporated into the control panel, which is often located by the hab door.
  4. golly
    golly Funster
    Aug 16, 2009
    1,210
    2,145
    Co Durham
    I think awning light switch is on cotroll panel marked AUX
  5. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,262
    Gobowen near Oswestry !!
    Auto trail !!!!!
    Mine hasn't worked since day 1 !!!!:Doh::Doh::Doh:
  6. Allanm
    Allanm Funster
    Jun 30, 2013
    3,243
    4,413
    Cotes d'armor, France
    Waste sensors on mine are useless too. I have had them cleaned twice, a week later, they give false readings.
    I have disconnected them and make sure I empty the tank every time I fill up with fresh water.
    Allan
  7. Sidney
    Sidney Funster
    Jan 27, 2013
    1,279
    833
    Stamford
    Close the grey water valve.
    Buy a bottle of Kilrock, pour half down the MH sink drain.
    Run all the taps until you see water in the shower tray.
    Leave overnight.
    Works every time :thumb:
    • Like it Like it x 1
  8. buckby
    buckby Read Only Funster
    Sep 6, 2013
    213
    148
    nottinghamshire
    The grey tank sensor on the autotrail only shows 0 or 100% nothing in between. According to the book.
  9. Baycott
    Baycott Funster
    Nov 6, 2013
    6,483
    13,571
    East Sussex
    We have the same van and what Golly said is correct.
    We also have the same problem with the waste indicator. It has never worked properly. I even took it back to the dealer and they said it was fixed but it was still the same. Don't bother with it anymore as we know roughly how much is in there most of the time. :thumb:
