Grey waste indicator (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
Having just returned from our maiden voyage in our 2006, Autotrail Tracker SE we are delighted with the experience and look forward to many such ventures.
Our only minor niggle was that the waste water indicator stayed showing 0% for the whole of our three days away despite going through a full tank of fresh water, most of which would have ended up in the grey waste. Is this likely to be a failed sensor? I am reasonably competent mechanically so would be happy to try and replace it myself if possible but don't actually know where the tank is...
And while I have your rapt attention, could anyone enlighten me as to the whereabouts of the external awning light switch? Hunted high and low but can't find it...
Many thanks, Jerry.
sennen523
45
14
Rhos-on-Sea, Conwy, North
Coachbuilt.
Started 2007.
Hi,
Almost certainly, the float switch arm is stuck because of grease etc.
Locate the bung on the side of the tank. (wires connecting).
Make a note of the bung fitting, usually has a flat edge on the bung.
Pull out bung and float assembly.
Clean and free off, check reading on panel when float arm is moved manually.
Push back assembly into the tank hole, ensuring the right way up !!
Al.sennen523.
motorhomer
680
418
South Shropshire
Van Conversion
since 2005 (but 30 years caravanning)
Many thanks, Jerry.
Try the easy things first. A good dose of thetford tank cleaner followed by a drive around might just clean the sensor area in the tank. I have found that once the van was more than about a year old this indicator always stopped working properly but usually the tank cleaner sorts it out - at least until the next time!
PP Bear
7,802
28,744
Kent, UK
Auto Trail Dakota SE
It's the same on my 2006 Dakota. I've seen it work just once in the 3 years I've had it :Sad:
It's been a mission of mine to get it working. Not that it'll make much difference. Once the tanks full, it'll dribble out of the overflow into the ground outside and the water draining in the sinks or shower tray slows down.
I've literally put a dozen dishwasher tabs (dissolved) into the tank and drove around hoping that this would shift it. Tank cleaner, tank freshener, RV grey water tank cleaner and every other type of cleaner have been added to the tank and it's only worked the once :Doh:
It actually has such a little impact on my time away. I could crawl underneath and try to remove it to clean etc, but I'd rather not break any seals into the tank :thumb:
I'll keep on putting the cleaner down the plug holes in the hope that I eventually shift the grime that's stopping it doing it's job and then see how it goes :Smile:
camocam1
1,112
788
Elgin,Moray,Scotland
bailey approach 760 se
since 2012
My sensors didn't work first trip away after getting the MH and came out the overflow on the grey waste tank. so went back to the dealer and he asked me if I was any good at sums !!!! Yea says me NO says him
100 litre fresh water tank 10 litre hot water tank and you filled it up twice so how do you expect that to fit into a 80 litre waste tank !!!!
Took out sensors and cleaned them lasted a few trips so now I just empty grey waste every chance I can and don't bother with the sensors
Apache
497
644
Rotherham
Coach built
5 Years
Mine is the same, and I just empty with a bucket every now and again. We did have a problem with water not draining away so I bought some Elsan waste tank cleaner and gave it a good few doses followed by a rinse out , then put some into plug hole and left to stand for a few days. This seems to have worked ok but obviously does little to cure the indicator issue. You might want to try putting some coke into the tank as I have seen suggested by others and see if this works
sean n maggie
672
327
leeds
autotrail
our awning light switch is the AUX button on our panel,,,confused me at first ,,but found out by trial and error,,,,and ours is a Autotrail too...:Smile:
Bazzermc
54
40
Wiltshire
Autotrail Cheyenne
I'm a newbie
I was under the MH replacing exhaust rubber mounts, thanks to another thread on this site and decided to take a look at the waste sensor.
We have a 2009 Autotrail Cheyenne 696.
Easy to pull out, clean and check the microswitch/float.
Made sure it was correct way up when put back in and will test next weekend.
GJH
29,450
38,827
None, now sold
2006 to 2022
I noticed earlier this year that the grey sensor doesn't work properly but don't know whether it is a dirty sensor (I clean our grey system after every trip using Buster Kitchen Fresh (or whatever it is called now)) or some other cause. I simply empty the grey tank every couple of days to make sure it doesn't overflow.
Chris
21,051
278,587
None
10 years
Same here.
Our level indicator for fresh and grey water in both our vans has been pretty rubbish.
DuxDeluxe
14,658
72,726
Planet Zog
A woosh bang van
since 2008
I noticed earlier this year that the grey sensor doesn't work properly but don't know whether it is a dirty sensor (I clean our grey system after every trip using Burstner Kitchen Fresh (or whatever it is called now)) or some other cause. I simply empty the grey tank every couple of days to make sure it doesn't overflow.
Rapido kitchen fresh would work so much better, Graham ;)
Reactions: GJH
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
wish i hadnt bothered to fit the tank sensors waste one stays on and the fw one tells me when ive run out of water
Feb 16, 2013
19,731
52,006
uttoxeter
ambulance conversion
50 years
Ours worked onece but it was empty at the time(n), the fresh water one shows full till its empty, but hey we know if the grey waters full when it overflows and we know when the waters empty when the taps stop working, simples(y)
RowleyBirkinQC
2,347
226,561
Dazed & Confused
Many thanks, Jerry.
We have same van and year as you, the grey waste level indicator doesn't work on ours either, but not something which bothers us (you should have an idea of water used from the fresh water tank usage). Interesting you used a whole tank of fresh water if you didn't empty the grey water, I thought the waste water tank was smaller (but you may have used it for toilet flush or other purposes, or ran out of an overflow I guess) - think the docs say fresh tank 81 ltrs / waste tank 49 ltrs...
I think the waste tank is somewhere under the shower room on ours, you can look under van at the rear offside and follow the grey waste tap/pipe (behind rear wheel) back to the tank.
The external awning light switch on our Tracker is the AUX button on the control panel above the door.
Kestrel
Autotrail SCOUT
Newbie
I purchased a drain jet washer hose that fits onto karcher pressure washers for £30 on Amazon
And fed it through drain pipe into tank. Also unscrewed large drain cap under the grey tank and fed drain jet through there also.
No more smells and tank sensors are working again!
