Grey waste emptying
Discussion in 'Top Tips & Tricks' started by Jack Slipper, Apr 9, 2016.
  1. Jack Slipper
    Jack Slipper Funster
    Apr 9, 2016
    140
    71
    Lancashire
    Hi, can anyone advise me of the best way to extend my waste pipe so we can connect to an on pitch drain please? Just got a Chausson 718 with the drain behind the offside rear wheel. Want something simple to push on rather than have to use clips ect. Thanks
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,954
    When we bought our Burstner it came with a Waste Water Pipe Extension (original part which pushes on to the waste pipe) plus a length of ordinary 40mm plastic plumbing pipe which the previous owner had left in the van and which pushes into the other end of the flexible pipe.
    For use at home I bought a length of pond hose (cheaper than motorhome hose) to which I attached a 40mm elbow at one end (so that I could push it on to the waste outlet) and a small piece of 38mm (I think) pipe so that I can attach a length of rigid pipe to reach the drain.
    Lengths of rigid plumbing pipe can, of course, be extended as far as you like with standard connectors.
  3. Tweedie
    Tweedie Funster
    Sep 14, 2015
    207
    149
    Northants
    We just bought a 2 metre length of caravan waste pipe. (grey ribbed type) No connectors needed as we got the correct diameter to just push over the end of the waste outlet, quick, cheap & simple and does the job.
  4. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,756
    10,481
    Norfolk and Toftir.
    We use a length of ribbed (convoluted) pipe left over from the fish pool, 28/32mm, can't remember. This may suit but there's plenty on ebay.
  5. Manic
    Manic Funster
    Nov 4, 2011
    1,135
    1,280
    Uk
    I bought a Vacuum extension pipe of eBay, extends from 1.5 metres to 9 metres.
    • Like it Like it x 3
  6. peter
    peter
    Nov 23, 2007
    39
    23
    Near Boston Linc's
    As above, works a treat.
    • Like it Like it x 1
  7. Zigisla
    Zigisla Funster
    Oct 24, 2015
    1,417
    1,559
    Fareham, Hants
    5 Mtr Vacuum cleaner hose - off of amazon, and a 90 deg plumbers joint for ease.
