Green screen using HDMI fro phone (1 Viewer)
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Since 2011, previously a tugger
Can anyone help?
When I'm connecting my Samsung phone via the HDMI connection on the Avtex tv via one of those little adapters to play some stored movies, I'm getting sound but a totally green screen. It works fine on tv at home.
Any suggestions techy folk?
Jaws
23,836
72,472
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Can anyone help?
Suspect it is the wrong format video file .. and the Avtex simply does not like it.. ( though I do not know for sure as there are so many Avtex options ! )
Do you know what file format your fone is using at all ? And what model Avtex is it ?
Minxy
32,649
66,541
E Yorks
Carthago Compactline
It'll be the file format as Jaws has said, Avtex TVs are quite fussy!
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
I don't think it will be the file type, if using the HDMI input the TV won't be accessing the file directly instead the phone will be using the TV as a monitor.
My guess will be an HDMI handshake issue, the phone and TV need to talk to each other to ensure the best picture quality. Check the settings on your phone, I'm not an android user but I would think somewhere in settings is an HDMI resolution setting. Also check the HDMI input on the TV is set to auto.
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
Connecting via HDMI relies on the source to play the media, the display (the TV) needs to be able to support the image resolution and any HDCP protection. A USB connection is a simple srorage solution which relies on the player (in this case the TV) to provide the transfer, decoding and playback software.
Nov 23, 2015
2,899
2,633
Newmarket,Suffolk
Benimar294
Newbie
I'm no expert, but it still comes down to formats, If the media player (connected via HDMI) isn't compatible with a format it won't play it.
Mickey.
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
Mickey.
You're correct about the media player having to be compatible, but it's the source device that becomes the player when using HDMI -the TV is a display device that just needs to be able to accept the HDMI signal.
Issues can occur if the display has older decoding software (HDMI 1.0 / 2.0) although hardware manufacturers are supposed to ensure backward compatibility. I've used my AVTex with HDMI 2.0 so that shouldn't be a problem and Dave(?) has used the phone and adaptor with another TV so that is compatible too. The only other things I can think of is a faulty HDMI lead or a HDCP conflict with AVTex, this would be unusual though if it worked with another TV.
It also depends on how the movie was obtained. For example -Apple disable all HDMI output on the iPad and iPhone for TV programmes downloaded from Sky and Virgin Media.
D
Deleted member 29692
That's nothing to do with Apple. It's the developers of each individual app.
For example SkyGo not working when you connect to an external display is entirely Sky's decision for licensing reasons. Apple don't care either way.
The same apps on Android and Windows devices are exactly the same.
