Grass Pavers - any recommendations?
Discussion in 'Motorhome Accessories' started by magicsurfbus, Dec 31, 2015.
  1. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,711
    8,790
    NW England
    When our 3.5 tonne MH comes home from storage we have to pull it diagonally across our lawn, which is creating a wheel rut. I'd like to counter this by laying some plastic grass paver tiles which will support the wheels but allow the grass to grow through them so the lawn doesn't look like a parking bay. I reckon I need about 4 metres x 40cms, colour green, and I don't want to pay any more than is necessary.
    Does anyone out there already use them, and if so are there any makes to go for (or avoid), and do you know any online suppliers who do a good deal on them? Thanks.
  2. wanderingyp
    wanderingyp Funster Life Member
    Feb 21, 2011
    269
    410
    Jersey
    See thread -
    New Driveway for Motorhome
    This is being discussed in it
  3. musson
    musson Funster
    Dec 25, 2013
    401
    140
    grantham
    Think they are the same as you can put a shed on try ebay.
  4. jdk62
    jdk62 Funster
    Aug 19, 2014
    548
    1,110
    I bought a load off eBay - they come in multiples of 8 from recollection. They are called Plastic paving driveway, grid turf lawn gravel protector drainage mat.
    Cost me £38 for 16 which included delivery.
    Easy to lay and very effective
  5. Landy lover
    Landy lover Funster
    Jul 11, 2009
    2,049
    4,195
    Zummerzet
    They are very good and will support a reasonable weight. The most important thing to remember the final result like all things will be down to the preparation. You will find it necessary to dig out and put stone in underneath just as you would with concrete. The grass paving is the final bit that will sit on your prepared surface. When you back fill you have a couple of options. If you have retained the grass then you can put it straight on top of the grass paving and then put a piece of thick ply on top and either use a wacker plate or just jump up and down on it and the grass will be pushed I the honeycombe. You will then end up with the same grass finish.
    Each manufacture will / should have a recommended maxium weight capacity and I have seen some with a driven weight and a standing weight given
  6. wanderingyp
    Feb 21, 2011
    269
    410
    Jersey
    • Like Like x 3
  7. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,620
    2,190
    Rutland
    I have over the years laid thousands of these both concrete and plastic ones .The concrete units are used on areas to cater for heavier traffic such as Fire engines ,so would support an Rv .
    The plastic ones would be fine for you as long as the ground underneath has been dug out and replaced with stone in layers and given adequate compaction,then lay the blocks on a bed of sand, fill with topsoil and seed.
    Grasscrete are a good make
    Vlad
