GPS Speedo ?
Discussion in 'Tech/Mech General' started by bjandlin, Mar 3, 2015.
  1. bjandlin
    bjandlin Funster
    Feb 29, 2012
    175
    98
    Reading & Surgeres France.
    Good morning, I have been wondering about the legality / acceptance of GPS speedos, (not the swimming ones)
    Thinking of registering our MH in UK, thought it might be an easier option than replacing kmh only facia.
    Does anyone have copy of construction & use regs or experience please ?
    Thanks.
    Barrie.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,698
    17,308
    YO11 2BD
    UK speedo must show MPH
    You can use an MPH overlay on your kph dial or simply tippex the corresponding numbers over the existing ones.
  3. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    Imported from Germany through mot with kmh no probs use dighud speed app on android phone or sat nav mph pretty accurate never had a ticket works for me .
    No doubt experts will be along soon :)
  4. SandT
    SandT Funster
    Oct 15, 2012
    127
    384
    Malta
    I use an old Satnav placed above the original speedo as I found my speedo pretty inaccurate .
    Works for me. :)
    Terry
  5. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,461
    7,280
    Derby
    My speedo cable broke recently (1991 van - proper cable)
    I will replace cable but will have to remove old one to have new one made, just need the time to do it
    Due for MOT, wondered if a GPS speedo or sat nav would pass MOT
    Speedo is included in MOT since 2012
  6. Mr Colpot
    Mr Colpot Funster
    Apr 29, 2009
    694
    249
    West Sussex
    Not sure as to the legality if stopped but working speedo is not part of the MOT as far as I know, and also some have suggested they (sat nav) are not as accurate when going up or down hill due to the satellite position overhead.
    Having said that I tend to drive but the Sat Nav speed than the Van Speedo - Sat Nav tells me when I am going over the speed limit for the road/motorhome also.
  7. Larby
    Larby Funster
    Jun 17, 2012
    1,696
    3,926
    North Essex
    I use my sat-nav as my speedo when in France, have it read out in KPH
  8. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,796
    Really? You would need to be driving down a really really steep hill for it to make any difference :eek:
  9. richr
    richr Funster
    Sep 5, 2014
    719
    991
    Cheltenham Spa
    I may be wrong , happens a lot [​IMG] I don't think a gps speedo is accepted as in construction and use regs
    Even if not a mot fail
  10. Mr Colpot
    Mr Colpot Funster
    Apr 29, 2009
    694
    249
    West Sussex
    Thanks - I don't worry about it myself but was only mentioning what I had read elsewhere.
    • Like Like x 1
  11. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,035
    7,974
    Forest of Dean
    Use our sat nav as speedo all the time check it against roadside speed indicators and its far more accurate then the speedo.
    Never had mph on our speedo and it passes mot every year.
    • Like Like x 1
  12. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Extract from the Department of Transport legislation
    Imperial Speedometer
    Great Britain uses imperial units for speed measurement. The law requires that speedometers must include a miles-per-hour display. Please note in particular that any modified display must be visible in daylight and in darkness.
    Markings may be added to the existing speedometer provided they are:
    • accurate;
    • durable;
    • can be seen clearly in daylight and when the instrument is lit during darkness.
    also
    That a speedometer has been fitted which is capable of indicating speed in both miles per hour and
    kilometres per hour, either simultaneously, or by operation of a switch.
    Note: We can not accept secondary devices, hand written changes or multiple stickers applied to the
    speedometer. We can only accept the changes detailed below.
    The speedometer must be marked up to the maximum speed of the vehicle, with graduations at 1, 2, 5, or
    10mph, and with values at intervals not exceeding 20mph. For this change we can accept the following
    options.
    a) That the factory fitted speedometer is dual marked as standard
    b) The existing (digital) speedometer is, permanently, re-programmed, through a standard feature of the
    vehicle, to display the vehicle speed in mph
    c) A miles per hour speedometer is fitted in-place of the factory fitted unit
    d) A professional, single, miles per hour, overlay is applied directly to the speedometer face plate, not the
    glass front plate (the overlay must be durable and accurate, with markings visible in both day and night
    driving conditions).
    e) A dual marked dial / facia has been added as a replacement to the factory fitted one
    • Like Like x 2
  13. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,685
    11,801
    Plympton, Devon
    I think this from above answers the question: "We can not accept secondary devices"
    A separate GPS speedo would be a secondary device I think.
  14. Barclaybasher
    Apr 13, 2012
    2,461
    7,280
    Derby
    Doesn't that mean that a replacement GPS speedo would be allowed if say the original did not function
  15. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,529
    5,622
    West Sussex
    The rules changed a few years ago 2011 I think, kmh speedo is legal for MOT but not for VCA (Vehicle Certification Authority). When you import a vehicle not you have to get an inspection done by a garage or MOT station and send a letter/invoice with your application form to VCA stating that Speedo Rear Lights & Headlights conform to UK regulations they in return send you a certificate that allows you to register the vehicle.
    Replacement dials available from Lockwood International, be careful in selecting the right one Fiat have several variations for each model, they are quick & easy to change.
  16. klaatu
    klaatu Funster
    Aug 10, 2013
    237
    200
    Scotland, Various
  17. Borderland
    Borderland Funster
    Nov 5, 2014
    422
    2,317
    Borders
    The GPS speedo may not work in tunnels because of lack of signal.
  18. Borderland
    Borderland Funster
    Nov 5, 2014
    422
    2,317
    Borders
    I imported a vehicle from Japan and had to have fog light fitted and the speedo converted to read mph. The speedo was an electronic type and the conversion was done using a convertor chip. The letter k on the kmph was blanked out so that it read mph. To get the vehicle registered it only had to pass an mot because it was over 10 years old.
  19. Clive
    Clive Funster Life Member
    Apr 30, 2012
    735
    1,131
    Canvey Island
    My sons speedy was broken on his car when it went in for a MOT, he forgot to tell them to replace it. The car passed and still has a broken speedo :eek:
    • Like Like x 1
  20. Barclaybasher
    Apr 13, 2012
    2,461
    7,280
    Derby
    Might be difficult top explain zero miles travelled next time though
    :)(y)
