Gps Mounted On Dashboard - Recommendations?? (1 Viewer)
Jan 10, 2013
5,958
7,354
Near Uttoxeter and Crete
Warwick XL PVC
Still trucking and learning
We've recently changed our motorhome from a C class to an A class and the GPS is now too far away when stuck on the windscreen. Does anyone have a recommendation for a good dashboard holder?
Thanks.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Jan 3, 2008
3,329
5,340
Pakefield, Lowestoft, Suffolk, UK
Looking
You can but a "Brodit: bracket which fits exactly for each different vehicle base, you then attach the satnav mount to that. I have a Fiat x250 and my mount is fixed at the top of the fresh air vent on the dash, that means my satnav is in easy reach and easy to see. Mine is a 5 inch Garman 3598 but if you had a larger satnav you would probably knock it when using the indicator stalk. Search "Brodit mount" on google to have a look. You can also as previously said in another reply buy, much cheaper ,round adhesive discs to stick on a flat piece of dash if you have one, but much depends your base vehicle
The Dudess
Jan 10, 2013
5,958
7,354
Warwick XL PVC
Thanks for all your responses - I have just ordered the 3M sticky one on ebay - £2.95 with free postage. Too far to drive to Halfords from where we live.
Eeyore
362
398
I found our TomTom kept falling backwards from the sticky pad so cut a section of foam pipe insulation ( the small diameter stuff) so that the base of the sat nav was held firmly in the slightly enlarged crack in the foam. I then shaved a bit off the base of the foam tube so it was flat and stuck firmly to the sticky pad.
One year of use and it's not fallen over yet...
Styx
570
2,086
Buckinghamshire
Van Conversion
since 2007
A friend put a link to this on fb the other day
http://www.cdslotmount.com/
don't know anything about it, just thought it was a smart idea - it's not £2.95 though... :frowny:
Sep 10, 2012
2,118
3,564
worcester
Sunliving van
Got a cheap Chinese rip off CD slot mount off ebay- about 10 days to arrive. Seems to do what I want holding 7 tablet running sat nav app.
Sep 10, 2013
1,186
18,688
Chelmsford Essex
Getting better
golly
2,001
69,093
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I have a Garmin and use one of these Broken Link Removed sits on top of the instrument binnacle so is directly in front of me.
The Dudess
Jan 10, 2013
5,958
7,354
Warwick XL PVC
Swivel the screen mount and stick it on the side window.....works for me.
The same as ppj side window works very well and cost nowt :)
Can't do this as hubby is the one who does the driving and therefore needs to see and I am the one who makes the changes to the GPS in transit.
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
The problem with those CD slot mounts is they place the Nav unit far to close to the cars Head Unit.
Most Navigation manufacturers advise against putting the Nav unit anywhere near the cars Head Unit as the strong magnets inside will greatly interfere with the radio signal.
I mounted our Garmin unit directly over the top of the HU in our Peugeot and it buggered the radio . The reception was woefully poor with much crackling and interference.
Reading the Garmin book for something unrelated I noticed the warning not to mount close to the HU.... So I got another plastic mount from Halfords moved the Nav and the radio is now fine..
Sep 4, 2013
200
200
North Hants
Chatsworth CV40
Motorhome since 1997 Camping since 1990
I too have always used Brodit mounts. These come in essentially two components:
  1. The dash mount - Made specifically for your vehicle and often comes with a number of different choices where you want it mounted. You can buy an additional mount for any other vehicles you are likely to use with your GPS.
  2. A Holder for your device - This is specific to the item you intend to hold. It could be for a phone, tablet or something else.
Each holder for each device can be used in any of the vehicles you have a mount so it is a very flexible system. More money initially but when you change vehicles you just buy a different mount.
I have my navigation on an IPad mounted in a holder with the dash mount in the centre of the vehicle pointing towards the driver. Works well for us.
The company in the UK who supplies these is DSL developments
Colin
Sep 2, 2014
1,023
5,392
Gloucester
Self-converted Van
Since 2014
We use one of these as we didn't want to permanently 'stick' anything to our dash. It's a rubber mat and stays by friction, only costs about £4.50 from Fleabay. Just about to order another one for the dash cam as we are so happy with the sat nav one.
Edit: just ordered another, £4.34 and free delivery!
GJH
29,450
38,828
None, now sold
2006 to 2022
If you have a cup holder on the passenger side of the console as we do (2003 Ducato) buy a tub of Broken Link Removed or Broken Link Removed from Superdrug. The tub is just the right size to fit the cup holder snugly and the suction mount sticks to the top well. We have tried it with both the Noza Tec and Garmin Camper 760 sat navs and they are both easy for the driver to see and for the passenger to make any changes.
Zepp
1,673
3,260
Roaming
7 Years
I have a A Class and the side window works for me
Paul
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
