Got it! (1 Viewer)
Stan Seagrave
5
5
Kent
Coach-built
I'm a newbie
Thanks, everyone, for your advice on petrol v diesel, etc. I finally stumped up a chunk of savings on this today...
http://s1214.photobucket.com/albums/cc495/MartianTom/?action=view&current=Motorhome.jpg
It's a Fiat CI Sirio, 1996, 1.9 TD, 4 berth, one owner from new, 38,500 miles, full service history, all receipts (even for headlight bulbs), 12 month's MOT, new tyres, shower, toilet, hob (no cooker, but that's ok), fridge, Fianna awning.... all set and ready to go! The chap who owned it was quite elderly and hadn't used it much for the last 4 years. It's as clean as a very clean whistle - no dents or marks - and the interior is as new. He was also meticulous, and the folder contains handwritten notes showing oil changes every 4,500 miles, regular services, etc. The layout is not quite as I'd have preferred it, but it's fine for my needs as there is only me! It was listed at £13,995 - but I eventually got it for £12,000. I lose the 3-month warranty for that, but it was serviced not so long ago and I'm not planning on doing huge miles just yet anyway. Finally... it's only 16 feet long, so will fit in my parking space with room to spare.
Well chuffed! Picking it up tomorrow... so, the world's my oyster this weekend :thumb:
Nov 30, 2009
6,543
148,332
Pickering
PVC the PUG
Enjoy your new toy. Have a lovely weekend out in her.::bigsmile:
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
Congratulations on your purchase, exciting times ahead for you. Sign up for a few Fun meets and show your new van off.
:flyingwelcome:
old-mo
Extra Special
16,341
93,473
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Looks a tidy set of wheels..
Hope you get lots of enjoyment and many happy trips.. :thumb:
P.S...............Not keen on the oversized "Funster`s Flagpole on the back".... :winky: :ROFLMAO: :ROFLMAO:
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
Stan,
Congratulations you seem to have yourself a little beauty there. Enjoy it! I am sure you will have lots of fun and as you have already discovered there is lots of good avice to be found on our funsters site.
Don't be afraid to ask questions no matter how silly you may feel, you may just ask the question somone else wants an answer to and is also afraid to ask.
Take your MH out for a short trip asap and try every piece of equipment to make sure it all works.
Norman
S
Stan Seagrave
5
5
Kent
Coach-built
I'm a newbie
Thanks for the encouragement and suggestions, folks. I picked it up this afternoon after a quick orientation. I took in most of what the salesman said, but I'll need to spend time with the manuals :Eeek:
It all seems pretty straightforward. Front brake pipes and rear shocks were replaced for the MOT. The mechanic said, though, that I ought to think about the cam belt if it hasn't been done. I've checked through the wads and wads of receipts that the previous owner kept, and though he was meticulous with things like services, oil changes, filter changes, tyres, brakes, etc, he doesn't seem to have had the cam belt done. The bus has only done 38,000 miles - but it's 16 years old, so I guess a new cam belt would be a good idea.
Is it an expensive job? And can any regular garage do it?
Another question. The fridge. The chap explained that I'd need to chill it down from the mains or gas first before it can be used. Once that's done, which would be the most economical way of using it: gas or 12v? I won't be using the electricity for more than lighting (which I'll keep to a minimum - and I may instead get some battery-operated LED lights) and for using a laptop. It was suggested that I get a solar panel for charging the leisure battery, but I was wondering if they really are worth the cost. Bear in mind that I won't be doing huge miles for a while, so the battery may not get a decent charge otherwise.
Thanks for any help.
Looking forward to that first sortie tomorrow... :Cool:
Jaws
23,821
71,988
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Congrats on the new van !! Looks a nice bit of kit :thumb:
I would DEF get the cam belt done.. well over due by the sounds of it.
And if you need a hob, number one sone has one brand new he bought for a race van but never used ... :winky:
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
Hi Stan and congrarts:thumb:The idea on your fridge is that you get it cold first on either gas or leccy---- leccy if you have access to H/Up at home before setting off :thumb: if not use gas :thumb:Once you set off you turn it onto 12v while the engine is running- when you get to where you are going turn it onto leccy if on hook up -gas if not:thumb:(It will not run on 12v if engine is not running:winky:)
Solar pans should not cross your mind until you see how you use the van and IF you need them-If you use site with H/U you will find you don't need them ::bigsmile: if wilding a lot consider adding another L/ batt first and see if that lasts you :thumb:The worst thing that can happen is you miss corrie for a night :ROFLMAO: If you find you run out of power AFTER adding the extra battery then it is time to consider spending money on solar :winky:
Ask yourself is it More a case of wanting rather than needing :Eeek::winky:
terry
haganap
12,712
25,981
planet earth
Carthago C Tourer
I'm an oldbie MH number 9
congratulations, and enjoy.
Yes yes yes to getting the cam belt done, you have saved enough on the purchase to get it done, normally around the £250-£350 depending where you get it done.
youv'e even saved enough to splash out on membership to fun now so your not be read only and can come and tell us about your weekend away:roflmto:
Douzeper
Nov 23, 2010
234
57
Antrim, Northern Ireland
Newbie
Health to enjoy!
I am still looking, I am eating and sleeping Motorhomes! I have looked at so many now I need to start again as I have lost track :)
lorger
9,632
90,387
Dumfries
Knaus Sun 650MEG
Well done on your purchase and hope you have loads of fun in it id get the cam belt done asap
