Go Outdoors Leisure Battery (1 Viewer)
Nov 28, 2015
46
9
Yorkshire
I was going to et two of these from Go Outdoors, has anybody any thoughts on them?
We will not be spending a lot of time in sites and have a couple of solar panels.
Broken Link Removed
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
It's 4.5kg lighter than my 110Ah traction batteries.
The plates aren't as fantastically thick as advertised.
I would say they would be OK as a battery for an on grid camper with occasional stops without EHU. If you are looking for serious off grid performance, look to spend a bit more elsewhere.
E
Nov 28, 2015
46
9
Yorkshire
Yep, you still need a card. I get one and share it with the family.
Thank you for the links, I will investigate.
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Only buy reputably manufactures battery's. There are so many 'sticker' battery's out there - you have no idea what you are buying.
Halfords don't make battery's and neither do the AA
Numax - Varta - Exide - Banner and a couple of others.
I have two of these.don't cut corners with Battery's - quality doesn't cost it pays.
https://www.tayna.co.uk/Numax-CXV35MF-P8275.html
Stud posts are recommended as you can add more cables easily and they save the cost of battery clamps.
Just make sure you get the nuts with them, some seem to be a special thread.
Don't cut corners with Battery's - quality doesn't cost it pays.
I've just looked at Lucas battery's and I'm not convinced even they are not a 'sticker' battery, they look identical to my Numax.
Here is an article I've just found - Interesting reading -------------- http://www.honestjohn.co.uk/forum/post/index.htm?t=21908
Cal54
3,806
62,013
Southport, UK
Leisuredrive Renoir
Since 1996
I know a fellow Funster who took the advise of Techno and bought from the Battery Megastore. Well pleased with his purchase both cost and delivery.
Jaws
23,836
72,472
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I took Andy's ( Techno ) advise and went with three Hankook ones.. Really really pleased with them
E
Nov 28, 2015
46
9
Yorkshire
Bought out last two from Tayna Batteries. Cheaper than GoOutdoors (do you still have to buy a discount card??), next day delivery, and the batteries are fine - do exactly what they should.
or their eBay store:
http://stores.ebay.co.uk/Tayna-Batteries
They seem great value, just a little
What size Hankook ones did you get?
Jan 31, 2016
1,117
606
Halifax
A Class Rapido 9097F
June 2016
110aH.. look on fleabay for deals on pairs ;)
Which is best? Deep cycle or normal batteries they seem to do two types
Also do 110,115 125ah is it worth getting a particular one or is it just which fits best as diff sizes?
Jaws
23,836
72,472
Thetford Norfolk
C class, Chieftain
Welllll.. I just took out my two 145aH batteries and fitted three 110aH ones..
Not that that helps as the reasons are boring, complex, and proly only of use to myself :)
Really what size you get is up to you.. I will say that like the old Yank saying of ' There is NO substitute for cubic inches' so the same goes for batteries..
What ever size you get, in a few months time you will be saying.. darn it, wish we had gone for the bigger ones !!! LOL !!!
Get deep cycle ones.. Normal ones fail really quickly as soon as they get lower than 15 to 20% of capacity
The fall off curve is really very steep
The name given 'normal' batteries is 'cranking battery'
They are capable of delivering massive amounts of amps but only for a limited time
Deep cycle leisure batteries cannot deliver massive amps ( the plates would almost certainly buckle and or the bus bars joining the plates may fail ) but are very good at recovering from quite deep discharges without permanent damage
In the past few years I have bought various things with the name Hankook on them]
All have been absolutely top notch and very well priced ( canna comment too much on the batteries other than to say so far they have performed really well, but they have only been fitted a couple of months so early days yet.. But the Hankook tyres I fitted to the old Miller were little short of amazing.. dug us out the quagmire more often called Newark show ground, kept us absolutely on track in the snows of northern Spain, and were whisper quiet compared to the old school Michelin Campers I took off )
Jan 31, 2016
1,117
606
Halifax
June 2016
Cheers which Hankook tyres did you go for?
Jaws
23,836
72,472
Thetford Norfolk
C class, Chieftain
Buggered if I can remember the numbers..
Basically they were 16 x 215 x 10 10 ply rated at 116 per corner ( 4.1 t van )
Just looked and I believe they were LT RA18
Lenny HB
53,424
149,957
On the coast in West Sussex
Hymer B678 DL
We only stock Banner and have had no problems with them over a number of years
Peter
I had two fail after 18 months neither Hymer or Banner would honor the warranty as they passed a CAA test which is a test for starter batteries meaningless for a leisure battery.
Do a serch of the German forums if you want to see how useless Banner batteries are.
Oct 18, 2014
1,858
1,157
Salisbury
Hymer B598 PL
Since 2013
2 X Duracell in current van, not sure what Hymer will place in new one
Lenny HB
53,424
149,957
Hymer B678 DL
Although the latest Elektroblocks now have an AGM charge regime I still don't think AGM's are reliable for leisure use, they were developed as starter batteries for stop/start engines.
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
Picked these up from Battery Megastore today as I was passing Ashchurch, the warehouse is very close to Jct 9 on the M5.
3 x DC 24. 88ah to go in the spare toilet cassette space in our garage to run an inverter.
2 x DC 31. 125 ah to replace the current 5 year old Banners fitted by Rapido.
4 x 25mm Link cables for the group of three
All for £356.25. (y)
Ed
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
At the end of the day what you are paying for is the number of cycles. If you are mainly hooked up that is not too important but of grid I would expect that you will start using up cycles quite quickly. Decent leisure batteries should offer over 150 cycles and traction/deep cycle 500+. Just as a comparison starter batteries may not survive more than 25 cycles. As for warranties just how do you the customer prove you have kept the battery properly when the company tells you you haven't
