glue removal (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
Strange one for here but........
My MH has had beam benders fitted in the past and i have just the remains of the adhesive on the lenses, any good tips for removal ?
Tried White Spirits, Petrol and a hair dryer but no joy ?
43,319
49,381
I assume, as you already tried petrol, that they are glass and not plastic.
Paint thinners or a similar solvent will shift it but avoid spills on the plastic bumper.
Brake & clutch cleaning spray should also do the job, available at most motoring shops and good for cleaning stubborn marks on the bodywork too.
pvw10
pvw10
273
45
Gloucester
Coach built
It's a Renault and they are plastic so have to be careful but petrol is no problem.
pvw10
pvw10
273
45
Gloucester
Coach built
Tried bog standard furniture spray polish?
Spray on, leave it for a while, clean off.
Usually works.
Cheers John,
Will deffo give it a go, if nothing else I will get smooth and shiney lights :)
Heyupluv
3,862
1,593
France,
touring many years..42+
Scotch 3m easy clean pen, for removing glue
We use one of these pens....very good.....but try in a small area in the corner first
when a glass and the barcode has left a mark when you pulled it off or have a desk and the kids have written on it with a marker ?
this product is for you from 3M Scotch range.
Great for removing:
Graffiti
Adhesive
Residues
Suitable for use on:
Desks
Lockers
Dishes
Glasses
Metal
Leather
and more
Due to its design as a pen instead of a fluid it is easy to use, accurate and you can keep it handy in a pocket, tool or craft box.
Link Removed
Link Removed
[ame="http://www.youtube.com/watch?v=XnRfuR-EuK0"]3M EASY CLEAN PEN.wmv - YouTube[/ame]
Its worth a try
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
I had the same problem,tried petrol etc ,eventually used a window scraper.The type with the Stanley blade ,make sure it's brand new as will have no nicks in blade which could scratch! Slow steady strokes,came off a treat.
Vlad.
pvw10
pvw10
273
45
Gloucester
Coach built
Vlad.
Good shout here but prefer chemical route as plastic lenses but if I can soften the stuff then it's a great idea for removal, ta.
Ridgeway
3,655
6,151
Lausanne
NiBi Arto 85E
Since 2012
This will remove anything.
C2HCl3
If the residue is hard to remove a hold a soaked cloth against it for a few mins.
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
Try Duraglit - metal polish wadding . My mum always used this in her shop to remove the sticky residue from price tickets.
Ridgeway
3,655
6,151
Lausanne
NiBi Arto 85E
Since 2012
Sounds perfect, is it legal he he.
Yes you can still buy trichloroethylene, in fact 3M sell it as a Hydro carbon cleaner. I can check which product if you need as I still have some samples lying around.
pvw10
pvw10
273
45
Gloucester
Coach built
Wow it's all coming in now, potions and lotions.
Have some Brasso so will try that.
I wonder if all these things I'm to try will make some explosive concoction !!
pvw10
pvw10
273
45
Gloucester
Coach built
Crikey I remember at work getting paint jigs stripped with Trike then they banned it, replaced with some more expensive crappy stuff, good move eh.
Samples? Yes pls
steveclecy
880
580
Wirral
Since June 2009
Last time I removed my beam deflectors it left behind a clear plastic sheet. I thought that was glue and tried to remove it with solvents.
In fact I was able to pick it off and only a minor amount of glue was left on the headlamp surface which was easily removed.
Steve
pvw10
pvw10
273
45
Gloucester
Coach built
Well it's 8.05 am stupid o'clock as excited about getting the crap off my lights.
I guess as plastic;
Wd40 fail
Mr Sheene fail
Duraglit fail
Brasso fail
So despite all your valiant attempts no joy yet, any more potions out there before I get the Kango out ?
pvw10
pvw10
273
45
Gloucester
Coach built
Steve
Thanks Steve, this is horrible, it will pick but tiny fragments and would take months and looks like scratches appear.
Heyupluv
3,862
1,593
France,
So despite all your valiant attempts no joy yet, any more potions out there before I get the Kango out ?.
YES...a new this
OR....or a new that
Link Removed
:RollEyes::winky::winky:
163phil
283
273
Kenilworth
Coach built
Still only a year after many years camping
Just a word of caution when removing beam deflectors from plastic lenses - go careful with the hair dryer. I did this on the bike a few years ago and the deflector came off nicely... together with the plastic film over the light. :Eeek: I then had no option but to block it down with 1200 grit and re-polish with Farecla G3 & G10 by machine. As good as new again now, but a lot of effort.
And as for petrol on plastic, again be careful, as it gets into the resin (plastics are porous) and, although will polish out, the staining will return. You'll be ok if you immediately wipe and wash off, but it will leach into the resin in quite a short time.
pvw10
pvw10
273
45
Gloucester
Coach built
Great shout- thanks
pvw10
pvw10
273
45
Gloucester
Coach built
Wa hey success
Tried an old fashioned razor blade, one with one side with like a cover on it so only one actual blade.
I held the blade as flat as I could to keep away from the lens and hey presto it worked a treat, the stuff just rolled away. I have marked the lens in one tiny place but that's fine, all done and well chuffed.
Thanks to all, as ever great support - now about this rash I have ........
Heyupluv
3,862
1,593
France,
Wa hey success
:RollEyes::winky::winky:....:ROFLMAO::ROFLMAO:.....I think the **x*** ********** ******* clinic may be best:thumb:
